Drawing a blank at the moment, wondering if someone could clarify the drawbacks of a standard container on a highcube chassis.
I'm pretty sure a highcube on a standard chassis will result in the pins not locking correctly, and the pins can come loose from the can bouncing around (generally when empty, loaded the weight will restrict the bouncing) causing an insecure load.
I could have it backwards?
Standard Container on Highcube Chassis
Discussion in 'Canadian Truckers Forum' started by BLBurton, Nov 3, 2022.
