just try to start up nothing much you can do as it needs to be programed as long as test ecu is from d12 it should not have any issues starting the truck.
Starting and Heads Up Display Issue
Discussion in 'Volvo Forum' started by Quickthrotl, Jun 28, 2017.
Page 4 of 6
Plugged the vecu in tried to start, blew the F15 fuse again
Basically no change -
ok do this try to install a taillight across the terminals on f15 it should light up when you have the short, then unplug relays one by one B30 is common power terminal for relays so if you have some circuit that's shorting out there is nothing across a relay what will use a load on the common and 87 pin sides .
if this is not making any sense call me and ill try to see if i can explain better 630-607-8889
Cool, I really appreciate your help, it's like 120 inside the truck, would it be ok to call you Saturday morning? I will have more time then or I will try to call you tomorrow. I do understand relays and how the work so what you are saying does make sense. Trying to make a living and fixing a truck is a pain in the ##*
i know trust me i got nothing but owner ops that come to my shop and definately respect when someone tries something on their own give me a call if you disconect relays one by one you will find the circuit that is causing this then it's a different ball game of what it could be causing it on that circuit.
We will find this, these trucks are not like the old days when it was an energize to run and push a button
i know there is not a problem yet on volvo specialy electrical that i haven't been able to fix yet so it's usually just a matter of time some take longer than others but its always a matter of time.
Quickthrotl Thanks this. -
Again I really appreciate your time
Hooked a tail light across F15, when you turn to start it lights up, started pulling relays, when I got to R13 Autoshift Start Enable it doesn't light up when you turn to start
Page 4 of 6
