So last week while we preloaded slag pots for this week. Somewhere in West Virginia, boss needed an extra escort to make the fun 12 mile run back to the pad site. While I've driven this route a few times and escorted a few times. I've never had to sit in a pick up behind a load and steer it.
Man I have to give credit to those that do this as a living. It was a stressful hour of turn this way and that way. Motor even stalled a couple times. Why we use gas motors on perimeter decks is a wonder.
Would I do it again? Hell yes!
Steered my first load
Discussion in 'Heavy Haul Trucking Forum' started by Landincoldfire, Jan 30, 2020.
I have found it even scarier to be 230’ ahead and trust a dude to steer you not into a ditch or sign or car or ....... It is a very odd arrangement1951 ford, SAR, RollinThunderVet and 7 others Thank this. -
1951 ford, blairandgretchen, D.Tibbitt and 4 others Thank this.
1951 ford, Isafarmboy, SAR and 12 others Thank this.
1951 ford, FoolsErrand, singlescrewshaker and 3 others Thank this.
Spend the better part of 2 years out there based out of Strasburg OhLandincoldfire Thanks this. -
Brettj3876 and cke Thank this.
1951 ford, SAR, blairandgretchen and 1 other person Thank this.
And I have very low standards for the right price
I will tell you - I would much rather pull my big trailer - at least I control the entire thing.
If you have a good steerman then the gig is easy , if you don’t you are. Totally screwed. Half the turns you can’t see anything in the mirror except for a white wall and the other half is so far back the tractor is around the corner and down the road before the rear axles and nearly 60’ of tail swing get to it1951 ford, Isafarmboy, SAR and 8 others Thank this. -
