Sterling truck clutch
Discussion in 'Trucker Forum Classifieds & Trading Post' started by owenzhou, Sep 20, 2023.
  1. owenzhou
    owenzhou Bobtail Member
    24
    Feb 10, 2014
    Dear sir,
    Could you advise the part number for eaton clutch? Thanks
    VIN: 2FZHATAK62AJ59181
  3. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,400
    6,618
    Oct 22, 2016
    North Dakota, Eh?
    Call the dealer and you’ll probably get an answer faster.
  4. owenzhou
    24
    Feb 10, 2014
    There is no dealer in China.
    BoxCarKidd Thanks this.
  5. Star Rider
    Star Rider Road Train Member
    1,505
    12,434
    Sep 23, 2019
    What engine and transmission?
  6. owenzhou
    24
    Feb 10, 2014
    CAT 3126 and Fuller manual transmission
  7. owenzhou
    24
    Feb 10, 2014
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,472
    6,509
    Aug 26, 2014
    Sterling falls under the Freightliner dealer umbrella. Most of them are not much on giving out part numbers if you are not ordering the parts.
    There are options. Pull or push type throughout bearing.
    What size is the input shaft? Probably 1 3/4" but measure it.
    Single or double disc? You can see them between the flywheel and and pressure plate in some applications.
    Some pressure plates have a part number tag on them.
    Some pictures through the inspection hole may help someone identify it.
    13 or 14 inch?
  9. owenzhou
    24
    Feb 10, 2014
    Input shaft 2IN 10 SPLINE
    14IN 2 disc
  10. BoxCarKidd
    4,472
    6,509
    Aug 26, 2014
    I am surprised no one helped you out by the serial number. I put one of those in a Kodiak with a 3116. It has been a while but I will see if I can find the numbers for you.
