Straight pipes and mpg
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bull hauler, Sep 12, 2013.
  1. bull hauler
    bull hauler Medium Load Member
    300
    80
    Apr 23, 2012
    Threw some straights on and after 3 fillups it appears im up 7/10 mpg...this possible? I have pdi turbo polished manifold and fuel temp mod. Went from 5.8 to 6.5, didnt think id see that big of jump
    baha Thanks this.
  3. Shade Tree
    Shade Tree Light Load Member
    177
    44
    May 15, 2011
    Galloway Ohio
    Bull hauler that is because you have less restriction and back pressure on the exhaust system.
  4. mikec265
    mikec265 Medium Load Member
    379
    188
    Oct 25, 2009
    Dumbed Down Land, WTF
    I can not stand the sound of straight pipes when i want to sleep, but 7/10 of a mpg........ id like to see how your numbers look long term. not to mention some places will bust your balls over straight pipes. my pittsburg power exhaust is loud enough.
  5. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    I picked up .5 mpg switching to free flow mufflers, so if he had really restrictive mufflers, he could very easily pick up that much.
  6. bull hauler
    300
    80
    Apr 23, 2012
    What came off was stock muffler dude said he gutted em but after seein the stacks shadow on the ground i noticed exhaust only comin out one side, anyway it runs lots better and mileage is holdin at .5-.7 depending how heavy i am, they are 13'7 tall so really aint too noisey. Wish i woulda done it last year
  7. SHO-TYME
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    If you do an oil analysis, your oil will be cleaner on the second oil change.
  8. bull hauler
    300
    80
    Apr 23, 2012
    Never thought bout that i sent a sample off last change ill check it after a couple more
  9. OLDSKOOLERnWV
    18,837
    284,027
    Mufflers??? What's that? :biggrin_25525:
  10. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    They have been trying to pass a law in the FMCSA that outlaw straight pipes without some type of noise suppressor. The old law stated that a turbo was a noise reducing device (I believe it was in 1976) and they want to get the law more up to date. I think it failed twice. But they keep trying. Here is a link to where they tried.. http://www.fmcsa.dot.gov/rules-regulations/administration/rulemakings/final/Noise-Emission-Standards.aspx
    And the actual rule..
    325.91 Exhaust systems. A motor vehicle does not conform to the visual exhaust system inspection requirements, 40 CFR 202.22, of the Interstate Motor Carrier Noise Emission Standards, if inspection of the exhaust system of the motor vehicle discloses that the system—(a) Has a defect which adversely affects sound reduction, such as exhaust gas leaks or alteration or deterioration of muffler elements, (small traces of soot on flexible exhaust pipe sections shall not constitute a violation of this subpart);(b)Is not equipped with either a muffler or other noise dissipative device, such as a turbocharger (supercharger driven by exhaust gases); or(c) Is equipped with a cut-out, by-pass, or similar device, unless such device is designed as an exhaust gas driven cargo unloading system
    mikec265 Thanks this.
  11. bgxpress2006
    bgxpress2006 Light Load Member
    248
    73
    May 25, 2013
    Montreal, Quebec
    try shutting truck off when you go to sleep, would also help your mpg... as far as busting your balls in some areas for straight pipes, cat's are not all that loud as long as you are reasonable with the peddle so take her easy going through small towns and scales and you will be just fine
