Surge Control Help
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Flatbedder73, Jun 9, 2013.
  1. Flatbedder73
    Flatbedder73 Medium Load Member
    Dec 30, 2012
    464
    Thanks Received:
    354
    Langhorne, PA
    I have been pulling Stainless and Asphalt tanks for about 5 months now, and am still not satisfied with my surge control. The lower gears are no problem, I just shift at a lower rpm...but shifting from 6 to 7 and 7 to 8 still gets me that little bump in the #####. I understand I need to accelerate after shifting to catch the trailer up to the surge, but how do you do that while climbing even the slightest grade? It's ticking me off that I can't get it perfect...and I know it is possible to do so. Anyone have advice?
  2. southpaw2153
    southpaw2153 Light Load Member
    May 10, 2013
    126
    Thanks Received:
    89
    It depends on the size of the load you have. If you have any things less than 40,000 lbs, it is going to be hard to avoid any surge. If you get a load with around 30,000 lbs, put your hockey equipment on and take any type of curves or turns verrrrrrrrryyyyyyyyy slowly.
    I much prefer to run with a full load, even though the truck is slower due to the weight.
  3. Flatbedder73
    Dec 30, 2012
    464
    Thanks Received:
    354
    Langhorne, PA
    I am always loaded to 45000. I love the way the truck feels at max wt....the asphalt doesn't surge much at all....even the one time I only had 20,000
  4. steerinwheelholder
    steerinwheelholder Bobtail Member
    May 31, 2013
    36
    Thanks Received:
    26
    wherever I park it
    Stop beating yourself up. Your load does it for you.
    Get a set oF tank load locks and your problem will be solved.
    RockinChair, perufb and Logan76 Thank this.
  5. GasHauler
    Oct 23, 2005
    6,257
    Thanks Received:
    4,365
    Vegas/Jersey
    I didn't apply a lot of power after the shift I just tried to make the shift as smooth as possible. Think of a cup of coffee filled almost to the top and sitting on the dash or wherever. When you shift you try to not spill a drop. Of course it's hypothetical but it worked for me. Or try progressive shifting, that will smooth out the shift. I hope you're not running the engine up to the peg and shifting. Because there's no sense in that and it wastes fuel and adds additional wear for no reason.
    Flatbedder73, chalupa and NDBADLANDS Thank this.
  6. Flatbedder73
    Dec 30, 2012
    464
    Thanks Received:
    354
    Langhorne, PA
    No, am very careful with the rpm....and am a very smooth shifter....just trying to completely kill the surge bump....am a perfectionist, and want to do the best possible
  7. jonboy29
    jonboy29 Light Load Member
    Jul 9, 2010
    297
    Thanks Received:
    187
    Home Sweet Home... SW Ont.
    shift, then wait for it to hit the back of the tank, then throttle away. I think you are shifting, and then trying to catch the load with the tank when it hits the front?
    lower gears are the hardest to get going smoothly, sounds like you got that part working for ya.
    brakecheck and Flatbedder73 Thank this.
  8. RockinChair
    RockinChair Road Train Member
    Feb 19, 2012
    5,065
    Thanks Received:
    12,749
    CC, TX
    I think that's the problem. Just accelerate gently, and that will keep the surge from getting bigger than it has to be. Take GasHauler's coffee cup advice.
    Flatbedder73 Thanks this.
  9. Flatbedder73
    Dec 30, 2012
    464
    Thanks Received:
    354
    Langhorne, PA
    Yeah...the lower gears are no problem....I will work on my rhythm for the higher ones....thanks!
  10. Logan76
    Logan76 Crusty In Training
    Jul 12, 2009
    4,528
    Thanks Received:
    17,698
    kittanning, PA
    Progressive shifting and taking it easy is all you can do, we load 48k every time 4300 gallons in a 6000 gallon smooth bore and some days its just going to beat you up....happens to the best of us, don't let anyone bs you about it...
    Keep on truckin' and you'll be fine.
    MJ1657 Thanks this.
