Swap d12 volvo engine
Discussion in 'Experienced Truckers' Advice' started by LG Transport 1210, Jul 2, 2022.
  1. LG Transport 1210
    LG Transport 1210 Bobtail Member
    I have 2007 D12 volvo engine and want to swap to isx cummins engine is it possible
  3. Gliding ProStar
    Gliding ProStar Medium Load Member
    545
    4,012
    Nov 12, 2016
    Waxahachie, Texas
    Yes,. Anything is possible with the right tools and money and a mechanic with experience in this type of work.
    Your best best for a swap like this is finding a complete donor truck of the same years that the ISX-15 was available and then use that donor truck to get every single part that you need.
    You will obviously need the engine, engine wiring harness, pieces from the body harness, any emissions components, the ECM, engine mounts, fuel system pieces, etc. Any fuel lines I would buy new because 2007 was 15 years ago and those lines are getting pretty old.
    LG Transport 1210 Thanks this.
  4. AModelCat
    125,093
    If the truck has no DPF from factory I'd try and swap a C15 in long before an ISX. At least the CAT wouldn't need EGR valves and VGT turbos every year or two, before finally sinking a liner at 600k.
  5. Gliding ProStar
    545
    4,012
    Nov 12, 2016
    Waxahachie, Texas
    A C15 whether it be a 6NZ or an ACERT is going to be a little harder because I don't remember a Volvo with a C15. I'm sure you could make it run but getting the instrument cluster and instrument panel working and cooperating is going to be a task.
  • Draft saved Draft deleted
