Teaming Logging
Discussion in 'Questions From New Drivers' started by jake.dontbrake, Aug 13, 2012.
  1. jake.dontbrake
    jake.dontbrake Light Load Member
    117
    18
    Jul 9, 2012
    My wife and I are new to trucking and teaming. Do we each need to log a Pre trip and Post trip when we swap drivers, as in, I get done driving and do a post trip, and she does a pre trip or vice versa? It seems redundant if she is checking everything in the pre I would be checking in the post, which is why I'm asking. What about sending in the Post trip macro on the qualcom, does that need to be done every time we mark we did a post trip?
    Thanks
  3. snowman01
    snowman01 Road Train Member
    1,246
    713
    Sep 27, 2011
    North Carolina
    Short answer is yes and no on the pre/post trips. You are pre-trip inspecting the truck so as long as you do not change loads, that is it is the same trip, you do not have to re-inspect the truck when you switch over. However, it takes at least 15 min to switch drivers so why not log one then anyways as this will cover you if a scale house or dot cop gets funky on you.
  4. NavigatorWife
    NavigatorWife Road Train Member
    2,937
    2,080
    Apr 30, 2012
    Cental West, AL
    I believe it has to be logged each time by both of you, even if you are related; if something happened on your shift the looks would go to you, not the other person. Some companies require a safety check I guess it is called in the evening also.
    Just make sure you don't run yourself out of time before you stop for the post-trip though.
    Good luck.
  5. pilottravel2002
    pilottravel2002 Medium Load Member
    688
    156
    May 25, 2011
    Tucson,az
    Just do it everytime u switch driver only takes 15 min,to be safe.
    DrtyDiesel Thanks this.
  6. fireba11
    fireba11 Heavy Load Member
    864
    541
    Jul 30, 2007
    Tracy City, TN
    i believe only a Pre-trip inspection is required by the DOT. However your company you drive for might require a pre and post trip on your logs. Check with your log dept.
  7. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    You have it backwards...Post trip and completion of DVIR, the "pre-trip" is a verification of the previous driver's DVIR. Pre-trip is flagged (no time on line 4) post trip is 15 minimum line 4.
    Yes each driver needs to complete the pre/post trip paperwork before/after their driving shift. There is no such thing as "team logs"...each driver is responsible for their own log, as far as "teaming", your two separate logs need to work together...in other words, you can't both be driving (line 3) at the same time, but you could both be sleeper (line 2) at the same time. Just apply a little common sense.
    Pedigreed Bulldog Thanks this.
  8. FozzyNOK
    FozzyNOK Road Train Member
    2,459
    3,786
    Jul 18, 2007
    Oklahomistan
    Pre-trips can be flagged.. Post Trips must be logged on duty
  9. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    amazing how different everyone thinks these rules are
    i can barely figure out me let alone my wife glad she is only a backseat driver
    "Why'd you go down this street I told ya................" sigh
    it would seem to me your company safty dept would tell you how they want things logged
    otherhalftw Thanks this.
  10. Allow Me.
    10,666
    12,184
    May 28, 2009
    Rancho Mirage, Ca.
    You can't accept the previous driver's report as valid (when driving different shifts) and you can't accept the previous driver's report as valid when driving team, either. Any pre/post trip is to double check either yourself or the team driver. YOU need to know the truck is safe and YOU know this by pre-tripping the truck, not accepting the previous drivers report.
  11. FatDaddy
    FatDaddy Road Train Member
    4,314
    10,375
    Dec 23, 2008
    Katy, TX or Swedesboro, NJ
    If I would have accepted my old co driver's post trip reports and not pretripping myself...well I probably wouldn't have a CDL anymore due to too many tickets.
