Temp controlled fan switch help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brick3268, Jul 26, 2026.
  1. Brick3268
    Brick3268 Bobtail Member
    I have a 1999 peterbilt 379 with the N14 select plus. I want to put in a temperature controlled fan switch for 195 degrees. But I also want to keep my 205 degree switch in as a just in case. Can someone tell me what I need to do or send a wiring diagram for it please. Thank you.
  3. MRMTRANS
    MRMTRANS Medium Load Member
    418
    446
    Apr 28, 2015
    It might be easier to put a toggle switch to turn the fan on manually.
  4. Big Road Skateboard
    7,865
    45,796
    May 2, 2021
    I guess you could buy a 195* fan stat and wire it to ground the fan relay. If they even make a 195* fan stat.
