Excuse my asking this newbie question, especially if it sounds ignorant. For you with the 12V coolers in your truck, I have a concern. They run off your truck battery, so won't they drain the batteries if left plugged in when the truck is not running/idling? If they would drain the batteries, I would think the coolers would need to be unplugged. This, in turn, would cause the coolers to warm up quickly, spoiling the food inside. Do I totally misunderstand how these coolers work?
Thermo-electric coolers (Coleman, Koolatron, etc) and batteries
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by doninwooster, Apr 14, 2018.
They only cool down about 30 or 40 degrees ambient temperature.
So if it is 90 degrees in your truck, the cooler will be 50 or 60 degrees.
They don’t draw a lot of power, so on a 10 hour rest you would be fine. On a 34 hour break you may want to start the truck once or twice. -
Koolatron has one with what they call heat pipe technology. Cools even better than that...
uncleal13 Thanks this. -
Except there are way better quality ones such as Engel or ARB. They cost over $600 and up.
They look like a regular cooler, but they have an actual compressor in them and can even be dialed down to below freezing. -
I never left mine running while I was out of the truck for more than a few minutes. They all (at least the cheaper ones, such as you find for 100-200 bucks at a truck stop or walmart) seem to have issues with the plugs heating up. I had more than a few plugs melt on me and I didn't want that happening while I was out of the truck and starting a fire.
If you are out of the truck for a day, throw some ice in there, or bring it in the house with you if you are going home. It's just as effective as any other cheap insulated cooler without being powered on.doninwooster and uncleal13 Thank this.
