Tire advice
Discussion in 'Experienced Truckers' Advice' started by Commuter69, May 14, 2021.
  1. Commuter69
    Commuter69 Road Train Member
    1,115
    618
    Jul 2, 2014
    Is this a normal wear pattern for steer tires at 80k-85k miles?
    Just trying to see if there's anything to be learned.
    Please help and say more than "not normal". Explain why and how to prevent it....
    And yes, they have been replaced.
    blairandgretchen Thanks this.
  3. JonJon78
    JonJon78 Road Train Member
    6,731
    35,621
    Jul 1, 2018
  4. Commuter69
    1,115
    618
    Jul 2, 2014
    Please explain what it means and how I can prevent it going forward.....
    Snailexpress Thanks this.
  5. JonJon78
    6,731
    35,621
    Jul 1, 2018
    I'm no expert but have enough experience as a driver/Owner Operator to say it is not normal.
    What kind of tires are those?
    When was the last time the truck had an alignment? How old are the shocks?
  6. natedogg323
    natedogg323 Light Load Member
    81
    118
    May 4, 2007
    Detroit, Mi
    I'm brand new to trucking but worked at Firestone complete auto care for 3 years. That looks like an alignment issue AND/or front shock issue. I have NO idea what the life span on truck parts are but on 4 wheelers, shocks should be replaced by the mileage you referenced in your post.
    slow.rider Thanks this.
  7. xsetra
    xsetra Road Train Member
    4,927
    6,587
    Aug 21, 2011
    JoeyJunk, DeereRunner97 and slow.rider Thank this.
  8. bad-luck
    bad-luck Road Train Member
    3,023
    5,437
    Nov 16, 2013
    Baltimore, Maryland
    Not normal. Would check the king pins
    JoeyJunk, 86scotty and DeereRunner97 Thank this.
  9. Commuter69
    1,115
    618
    Jul 2, 2014
    Original to the truck at now 402k. Pictures were about 7500 ago.... I don't remember what brand name the tires were. I just get paid to get from point A to point B, alert the office when something is wrong/needed; but not decisions related to any sort of solution to an issue outside of daily type safety/hours use/routing type of things
  10. Dave_in_AZ
    315,471
    That has to shake your liver loose at lower speeds.
    That's not only whacked, those are dangerous. And you should get the front end checked and those tires replaced immediately.
  11. uncleal13
    uncleal13 Road Train Member
    3,757
    6,199
    Apr 9, 2009
    Humboldt, Sk
    What pressure do you have in them?
