Tire pressure for my 2017 toyota hino 300-820?
Discussion in 'Questions From New Drivers' started by iec, Oct 4, 2022.
  1. iec
    iec Bobtail Member
    5
    Oct 4, 2022
  3. Allow Me.
    10,367
    11,207
    May 28, 2009
    Rancho Mirage, Ca.
    Posted on door jam ? Or on tire, but that is MAX pressure when loaded
  4. bowlwinkle
    bowlwinkle Heavy Load Member
    816
    687
    Aug 27, 2008
    Ankeny, IA
    Should say on the tire
  5. MartinFromBC
    2,769
    12,467
    Oct 19, 2018
    Open the drivers door, look near the latch area on the truck, it will give front and rear tire psi.
  6. Moosetek13
    Moosetek13 Road Train Member
    13,798
    16,304
    Nov 1, 2010
    Burnsville, MN
  7. iec
    iec Bobtail Member
    5
    Oct 4, 2022
    Nothing on the doors & no manual...
  8. iec
    iec Bobtail Member
    5
    Oct 4, 2022
    On the tire it's 105 psi… i assume it's the max…
    If i'll put 95 it's ok?
  9. iec
    iec Bobtail Member
    5
    Oct 4, 2022
    So i saw on the tires max 105psi for the rears & 100psi for the front.
    Because it's the maximum, i put 96 for the front & 99 or 98 for the rears… is that enogh/ok?
    Thanks for the help.
    MartinFromBC Thanks this.
  10. Ridgeline
    20,722
    100,942
    I would chalk the tires, it will give you a perfect pressure.
    ALSO those look like 17.5 tires, so 90 to 100 should be good. I doubt if you are close to the max capacity of the chassis.
    Where are you by the way?
  11. MartinFromBC
    2,769
    12,467
    Oct 19, 2018
    That is plenty, maybe even a bit high.
