Tolerating cold temperatures without having to idle.
Discussion in 'Experienced Truckers' Advice' started by TallJoe, Jan 14, 2018.
temp below which you need to idle to generate heat
  1. 30F
    11 vote(s)
    21.6%
  2. 40F
    20 vote(s)
    39.2%
  3. 50F
    12 vote(s)
    23.5%
  4. 60F
    8 vote(s)
    15.7%
  1. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    I can manage 40F and above. I shut down the engine and enjoy the silence. Though you have to be careful for sudden temperature drops. I had a situation when it dropped down to 15 .... I woke up pretty stiff. What about your tolerance; at what temp do you need to idle to generate heat?
    Or turn on your Webasto or APU?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    You need to go much lower to get my vote.
    -24F (-30C) for me.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    I maintain a temperature in that cab 24/7 with the engine. Sometimes there are food items that should not be allowed to get cold or hot.
    I recall one 60 degree day up near Scranton I shut down and went ahead and killed the engine, been running hard a while. Windows open, bug screens in and bed.
    The following morning I woke up sitting in snow that had blown in and ice 4 inches thick around the drives and something like 26 or so with a brisk storm wind. Now I was no where near appropriately dressed for that temperature and condition and it was COLD. Im glad she cranked because she gets a little temperamental when it's really cold. (Wet fog near the sea usually really makes it bad...)
    There have been a number of times Ive gone to hibernate in dead old iron with a candle going on the floor waiting for the rescue mission to arrive during winter storms. You sort of do not go to sleep, because you might not wake up. We carried a small wood bench that went across both seats in them days.
    Finally another cold incident was actually a log book problem with my famous one tank ATS tractor. Fueling two or three times a day to get anywhere. (Disgusting...) I finally ran out of hours and no way to work around it until midnight. Not only I was out of hours I had about two gallons left in the tank by stick. So I had to shut engine off in the cold. It did have a wabco heater for the sleeper and I used that. (It did good but burned more fuel we did not have...) Fuel line was about three parking spaces away and I was able to get some tankful at midnight.
    Im pretty certain that if I had two tanks with that company I would not have had the constant appointment killing shorts on fuel and hours. It's ridiculous.
    That's enough about this for today, Im pretty sure others have stories to tell.
    TallJoe, tucker and rolls canardly Thank this.
  5. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    50 and 60 degrees? perfect sleeping weather. 40 i sit with the engine off even. 30 might get fired up every few hours to take chill out if its windy or something. i have no apu or anything.
    TallJoe and Opus Thank this.
  6. tinytim
    tinytim Road Train Member
    5,143
    18,237
    Oct 29, 2007
    Northern Ontario
    Without a bunk heater I'd be idling at around 40/45.
    Hurst Thanks this.
  7. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,542
    May 22, 2017
    Honestly you can stay real warm down to 0. Go to YouTube search Fortress clothing. Made in Utah. I want to get their products so bad, but not cheap.
    disoba Thanks this.
  8. tinytim
    5,143
    18,237
    Oct 29, 2007
    Northern Ontario
    I can stay warm colder than that but I want a comfortable temp in the cab.
    stwik and Tb0n3 Thank this.
  9. 201
    201 Road Train Member
    12,275
    25,061
    Apr 16, 2014
    high plains colorado
    Baloney, just idle the truck.( step it up to about 1000 rpm's, tho) This argument is as old as the hills. Your boss doesn't sleep in a cold room, neither should you. Years ago, you didn't dare shut a truck off. If it didn't start, the service call and being late, would far outweigh the cost for a few hours idling. Cost, about 1 gallon/hour and you'll be on time for your delivery.
    stwik, Dna Mach, rank and 7 others Thank this.
  10. Grumppy
    3,085
    10,555
    Dec 11, 2010
    West Monroe, La
    When I am home... when my boss is home.... when the company owner is home...
    we all are either running heat or A/C, especially for a comfortable nights sleep. So, my boss & the company owner, allows me... to stay comfortable at night in the truck as well. They are comfortable at home with heat & air... I am comfortable at home with heat & air.... why shouldnt I be comfortable while away from home cooped up in a 4 X 6 sleeper? I'm glad I have humans who respect humans as themselves to work for.
    Above 60ish... its AC, below 60ish, its usually heat... either as needed.
  11. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,825
    Dec 7, 2015
    OK
    I wish I could vote twice since the 50's feel warm in the spring but the 60's feel cold in the fall
    Suspect Zero and tinytim Thank this.
