Too much oil problem?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by The blue guy, Apr 29, 2015.
  1. The blue guy
    The blue guy Light Load Member
    83
    4
    Jan 4, 2015
    I have a 12.7 Detroit Series 60. 850k miles, running great, checked the oil level last week and it was short 1/2 gallon. Checked it today and Oil level has 1 gallon too much oil according to the dipstick. The oil does NOT have a fuel smell to it.
    What I can see is; I have to change the fuel filter because its been overdue for aprox. 1 week now.
    The oil is thin and lost 1/2 gallon of coolant in the past week.
    P.S. The truck is still running perfect and cant feel any difference and I am still averaging 6.5mpg
    Any suggestions?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    well don't run it until you determine why it is making oil. either fuel dilution or antifreeze. an oil sample will tell you. if you lost a half gal of coolant and it didn't leak out in the open you pretty much found your problem. ie headgasket or pitted liner or cracked head or bad liner O-rings to name a few.
  4. Aleeex
    Aleeex Light Load Member
    150
    78
    Jun 8, 2014
    Sacramento
    Speedco can do an oil analysis.. I also have used black stone labs.
    Get it done asap. You don't want to spin a bearing
  5. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    First question. Are you sure your reading and checking the dipstick correctly?
    I like to check my oil cold. Before I start the truck after it's set for the night, I pull the dipstick, and I don't even have to wipe the stick off. Just pull, check, add if needed, and start. Never overfill.
    Second. Did you add oil when you saw it was short?
    Either you overfilled it, or that lost coolant is in your oil pan and you need to drain. I'd just go ahead and change it, cheap insurance. When you drain, pull a sample and send it to a lab for testing.
  6. Heavyd
    Heavyd Road Train Member
    7,768
    6,207
    Feb 4, 2009
    Yes, only check oil at the start of the day/run when the engine is cold and the oil has settled. Oil will expand in volume when hot, so the level will go up if you recheck it when hot.
    Diesel Dave Thanks this.
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    if there is a yellowish milky color on the inside of oil cap, then coolant is getting into the oil. on a detroit it is not uncommon for the air compressor head to go bad & put coolant in oil, I had a rebuilt air compressor do this less than 2 years after put on. this is very inexpensive to do, if that's it. it can certainly cause your symptoms.
  8. wore out
    wore out Numbered Classic
    15,845
    191,683
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Yea I would pull the pan and pressure test the system before I went to ripping bolts out. Water pump and air compressor are real common sources if it's determined to be coolant. Don't assume anything at this point. That will cost you
    The blue guy Thanks this.
  9. oldtrucker66
    oldtrucker66 Light Load Member
    299
    211
    Jan 1, 2015
    You can do a field test to check for coolant in oil.
    Take either a spoon, half a soda can, small frying pan, (or similar metal container - make sure they are clean and dry) and heat until very hot. Drop a few drops of oil on it. If it crackles and pops, you have water/coolant in oil.
    One alternative is to drop oil on hot exhaust manifold.
    Still another is to heat dipstick with a Bic lighter (done away from truck).
    These methods are not 100% perfect, but they can be done quickly in the field.
    Also, I'm not suggesting these replace having oil checked by a lab.
    icsheeple and baha Thank this.
  10. The blue guy
    83
    4
    Jan 4, 2015
    Thank you for all your feedback! I will get it tested before I go and blow thousands down the drain!
    If water is in the oil what can be the issue?
    If fuel is in the oil what can be the issue?
    If coolant is in the oil what can be the issue?
    Thanks
  11. Heavyd
    7,768
    6,207
    Feb 4, 2009
    Actual water in the oil is usually condensation and usually only very minor and will evaporate once the engine is hot. Seeing water drops on the inside of the dipstick tube or on the dipstick is normal from condensation. Fuel will be from an injector leaking. Coolant is normally from injector cups, but could also be from the oil cooler or liner orings or a cracked head. Coolant mixed with oil usually forms a greyish snot on the dipstick. Oil level going up due to coolant leaking internally will cause a dramatic change in the chemistry of the oil and should be very noticeable. Oil will change colour and smell weird. With the increase you describe, I would guess it is fuel leaking from an injector. There is a point where fuel will mix with the oil and still be hard to tell fuel is in there. Lab testing will confirm.
