Torque numbers and Dyno. Too high
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by stanton, Sep 24, 2022.
  1. stanton
    stanton Bobtail Member
    8
    Nov 5, 2020
    Please see the attached torque numbers. 2500-2800 ft lbs. Between 1200 and 1600 RPM.it is a Fitzgerald Glider, 600k miles. Under 19,000 hours. Peterbilt 579.
    I am looking for reliability and mpg. What do I need to change?
    How is low HP so low, never touched 350, while torque is dangerously high. Turbo psi gets above 40 as well. Just had a head gasket replaced. Oil pan was leaking as well. Along with rear main seal replaced.
    Vid of blowby:
    https://youtube.com/shorts/4UWCFUCMJq4?feature=share
    Many thanks
    singlescrewshaker Thanks this.
  3. 062
    062 Road Train Member
    5,460
    18,162
    Oct 20, 2013
  4. Rubber duck kw
    5,935
    17,188
    Dec 9, 2017
    Either their dyno is on the fritz or the guy who ran it don't know what he's doing. That sort of torque with that little horsepower is unlikely if not impossible without massive stroke.
  5. AModelCat
    131,659
    More than likely an error.
  • Draft saved Draft deleted
