Trailer Brake Lock Up Blocking Traffic
Discussion in 'Experienced Truckers' Advice' started by silverspur, Oct 7, 2026.
Page 1 of 3
Usually, depending on the problem, the brakes will more likely become unstuck by pushing backwards than pulling forwards. Pulling forward usually cause the brakes to grab harder. So if in doubt, push backwards first and STOP pulling forward as soon as you notice the problem, not pulling forward harder and harder until you have made the problem worse.
SoulScream84, Lite bug and silverspur Thank this. -
Other day just after a service at the dealer, just far enough away not to scull drag it back, and just after building it up to 55mph on a connecting road, bang left front on the tri locks and its smoking hard for the next 300ft till I can pull over. The rubber hose they kindly replaced is 4" short, so no matter how good the clamp is, with a bit of travel it just pulls off. Trailer brake on it made no noise, trailer brake off and it blew air loud and clear. Tscottme is right cause once fixed the truck didn't want to go forward, but after small reverse everything freed up and worked fine. Think the dealer wanted to know about the $850 on new tyres.
SoulScream84, tscottme, silverspur and 1 other person Thank this. -
I think the backward push is more effective at releasing the brake(s) and it has to do with S-cam, if those are even on truck brakes anymore. Think of the upper right corner of the S as being the contact surface of a brake turning clockwise. As vehicle moves forward more and more of that S comes into contact with brake, which increase resistance to moving. But, if you think of the brake moving counter-clockwise then it pushes the S more toward upright position and there is a lot less of the S able to contact the brake surface. That's my theory, anyway.
A helpful Michigan garbage truck driver told me about backing up when I tried to leave a frozen rest area with one axle frozen stiff but every thing else rolling normally. That's when I learned why they paint wheels and tires or add those little flag things on wheels up in snow country, so you can see if wheel is rolling or just sliding.Feedman, MACK E-6, jaffles and 1 other person Thank this. -
Looks like he overshot his fifth wheel!
Big Road Skateboard, Magoo1968, RockinChair and 5 others Thank this. -
Interesting! If the brakes do not release with the air up I always work the vehicle back and forth. My idea or someone taught me? Shoes can wedge into a drum and just get tighter the harder you push just like a door stop. Never knew why strips are painted on tires.Rideandrepair and tscottme Thank this.
That's what I was thinking, too.
But if the brakes really are locked up, cage 'em and get that darn thing out of the way.
Of course, he might have overshot his fifth wheel and not realized it until his brakes locked up, causing the kingpin to slide around the edge of the fifth wheel during that turn.Sons Hero, tscottme, Lonesome and 1 other person Thank this. -
If have wrenches, can always back the brakes off
tscottme Thanks this. -
There's no if i have.
I always have sockets.
99.99% don't and wouldn't have a clue anyways.
Some companies don't even allow it.
Page 1 of 3
