trailer brakes won't hold
Discussion in 'Freightliner Forum' started by BHarbinson74, May 5, 2022.
  1. BHarbinson74
    BHarbinson74 Bobtail Member
    18
    17
    Oct 7, 2020
    Posting on behalf of someone else and it's got me scratching my head too.
    Thought I'd pick the brains of those more knowledgeable.
    Truck: 2012 Cascadia 125 day cab
    Issue: Trailer brakes have been measured and are adjusted correctly. If trailer brakes are set he can pull forward and the wheels still spin. They don’t feel like they are working right while driving either. He has replaced the tractor protection valve and it didn’t fix the issue. The truck doesn't have a Johnny Bar so he hooked the trailer to a different truck with a Johnny bar and the brakes work like they are supposed to. This would indicate that the issue is on the truck side. Any suggestions?
    truckdriver31 Thanks this.
  3. Big Road Skateboard
    1,510
    5,862
    May 2, 2021
    Maybe a quick release valves on the supply line isn't exhausting air, or the supply line is kinked.
    Have him release the brakes, let it air up thr trailer, then set. Remove the red glad hand and see if there's air
    Oxbow Thanks this.
  4. GYPSY65
    GYPSY65 Road Train Member
    1,458
    3,466
    Nov 16, 2012
    SW FLA
    Deleted
    Didn’t read the entire post and it answered my thought
  5. Shawn2130
    Shawn2130 Heavy Load Member
    855
    1,738
    Sep 20, 2015
    Ontario
    Sounds like an issue we are trying to fix with one of our dump trucks.
    Doesn’t park right and doesn’t brake right.
    Brakes are adjusted and there’s 3/4 lining left.
    It’s been an on going issue that’s never been solved yet.
  6. truckdriver31
    6,939
    8,218
    Sep 18, 2013
    Are airlines hooked up correctly. Red to red blue to blue
  7. Around the block
    Around the block Bobtail Member
    9
    18
    May 6, 2022
    Might have a broken brake chamber spring or two... Would explain why the hand valve will hold it back, but dynamiting them won't. Not uncommon. Smack the chamber with a hammer and listen for anything rattling in there.
    truckdriver31, Shawn2130 and lester Thank this.
  8. gentleroger
    gentleroger Road Train Member
    5,238
    12,411
    Jun 1, 2010
    Does it have a trailer hold switch?
  9. North Pole Nightmare
    North Pole Nightmare Light Load Member
    154
    245
    Dec 15, 2021
    Did you find the problem?I normally start at the wrong end of the truck and check everything,until I find it,so I'm not much help on this one.
    truckdriver31 and Rideandrepair Thank this.
  10. BHarbinson74
    18
    17
    Oct 7, 2020
    there is air coming out of the red line as well as the blue when you press on the brake
  11. BHarbinson74
    18
    17
    Oct 7, 2020
    Yes, the air lines are hooked up right.
  • Draft saved Draft deleted
