Trailer clearance light out
Discussion in 'Freightliner Forum' started by WhenPeopleGoMoo, Jan 24, 2020.
  1. WhenPeopleGoMoo
    WhenPeopleGoMoo Bobtail Member
    5
    Dec 4, 2019
    Hey, everyone. Sorry for the very repetitive question everyone has asked already. I have a right side trailer running light that is out. Turn signal and four-way flasher both illuminate and work properly. I cleaned the trailer connection pins. I also unplugged the actual wiring on the light and plugged it back in. To try and see if it wasn’t seated properly maybe? I’m out of ideas. Still not working.
  2. WhenPeopleGoMoo
    5
    Dec 4, 2019
    Also, forgot to mention I checked the trailer fuses as well and changed them just in case.
  3. rachi
    rachi Road Train Member
    3,218
    2,517
    Feb 25, 2010
    SoCal
    Look for a broken wire near the light.
  4. Milr72
    Milr72 Medium Load Member
    379
    755
    Dec 16, 2011
    S W Missouri
    Have you tried replacing the light?
  5. xsetra
    xsetra Road Train Member
    3,563
    3,340
    Aug 21, 2011
    Did you check for power at the light? IF you have power, the light is bad. If you don't have power, check the wire.
    ZVar Thanks this.
  • Draft saved Draft deleted
