Trailer hub oil leak, will I get written up on inspection? (picture)
Discussion in 'Experienced Truckers' Advice' started by silverspur, Jul 3, 2022.
  1. silverspur
    silverspur Medium Load Member
    675
    1,753
    Sep 26, 2012
    Is oil leaking out of outside trailer hub something a driver can get written up for during a roadside inspection? This is a yes or no type question. Feel free to expound on YOUR personal experience after replying "yes" or "no". Thank You
  3. Keepforgettingmypassword
    Keepforgettingmypassword Light Load Member
    286
    438
    Jan 11, 2022
    I had a similar issuse. Easy fix for the shop. Watch them and you can do it it next time.
    I don't know if you can get wrote up for it. But I do know you don't wanna let it all drain out.
  4. rpad139
    rpad139 Heavy Load Member
    788
    506
    Jan 9, 2014
    Ca
    The experience trucker will say nay. But we are in the year 2022. I cant help you
  5. 48Packard
    48Packard Ol' Two-stop Shag!
    8,167
    9,093
    Apr 19, 2009
    Could be anywhere
    This is solely based on my experience.
    That particular example might be a problem. I’ve hauled a lot of old trailers over the years, and many of them exhibit this “seepage”. The actual gasket seems to be the issue.
    It’s a simple fix. If you can, check the tightness of the nuts. If they’re ok, get the repair done.
  6. Arctic_fox
    Arctic_fox Road Train Member
    1,422
    4,744
    Sep 16, 2016
    This is not a yes no answer. Most of the time no. But its not unusual for dot to nail you for piddly crap nowadays.
    Honestly just get it fixed. Hub ends are $150 each installed or at least they are on my trailer and avoid the issue.
  7. 50WT
    50WT Light Load Member
    250
    1,630
    Dec 26, 2015
    It's not leaking much , it hasn't slung any oil on the wheel. I doubt you'll have any problems.
  8. 062
    062 Road Train Member
    5,227
    14,296
    Oct 20, 2013
    I would pick up a new plug and clean up the hub. Most Ta/petro will have a plug. Take that plug in with you.
  9. kwswan
    kwswan Road Train Member
    1,607
    7,908
    Jul 26, 2009
    mcminnville,tn.
    The right cop will write it up as a leak. My son was stopped by a Lexington KY city dot a couple of years ago and wrote up for 3 just like that.
  10. D.Tibbitt
    108,653
    Theres a pin hole in the plug . its a breather hole, when it gets plugged up they like to seep like that. Run a paper clip thru it to allow air flow.
    86scotty, shawnhhllc, Oxbow and 11 others Thank this.
  11. silverspur
    675
    1,753
    Sep 26, 2012
    Do I even have this trailer with me? Half the trailers at my company have this problem. There is much more to it than I care to explain.
  • Draft saved Draft deleted
