Trailer parking brakes are not setting
Discussion in 'Freightliner Forum' started by Dorego401, Mar 31, 2021.
  1. Dino soar
    Dino soar Road Train Member
    4,813
    27,058
    Dec 8, 2017
    Are you sure?
    I thought every trailer after a certain date had to have spring brakes.
  3. Dorego401
    Dorego401 Bobtail Member
    31
    5
    Oct 11, 2020
    Thanks , I’ll try this! Lines are hooked up correct , if they weren’t I wouldn’t be able to move ‍♂️. I’ll have to also adjust the brakes this weekend
  4. SmallPackage
    5,772
    18,528
    Dec 20, 2019
    Marion Texas
  5. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    years ago. u had to hook up airlines before backing under trailer. if you didnt. the trailer would move around
  6. AModelCat
    164,186
    Unless it was a recent change. Seen a few pole trailers from the mid to late 90s with just service pots. Even a couple years ago I believe you could spec a new lowbed without spring park chambers.
    Dino soar Thanks this.
  7. Dino soar
    4,813
    27,058
    Dec 8, 2017
    I just to be clear I wasn't doubting you. I am sure that if you say it that's the information that you have to work with.
    Is it possible that in Canada it's different? Because here in the states I thought it was mandated like ABS brakes after a certain year.
    I certainly could be wrong but that's what I thought it was.
  8. SmallPackage
    5,772
    18,528
    Dec 20, 2019
    Marion Texas
    Abs was required on all Tractors built on or after March 1, 1997. Trailers and straight trucks March 1, 1998.
    There are still 4 catagorys of trailers that are exempt from needing spring brakes.
    Canada pretty much follows the same rules since FL, KW, White-WesternStar were all built up there when the original fmvss 121 brake legislation was enacted in the early ‘70’s.
  9. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Like thats any different from normal?
    I wouldnt advise anyone to adjust brakes if they dont know what theyre doing, but how about this. Had a shop do my brakes and drums, got truck back, brakes werent right, did my own adjustment, they work right and i found i need to replace a slack adjuster, ratcheting pawl isnt working. That ase shop adjusted wrong AND failed to inform me of an obvious mechanical fault
    John E Walker Thanks this.
  10. AModelCat
    164,186
    Back in the day drivers were expected to know how to adjust their brakes. Blows my mind you need a certification to measure pushrod stroke and adjust it if the auto slack is shot.
  11. Ridgeline
    22,715
    122,782
    Only if you are working on them as a nondriver.
