Trailer suspension air pressure gauge.
Discussion in 'Experienced Truckers' Advice' started by Midnightrider909, Dec 17, 2016.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    I'm just wondering if such a thing exists. I have a gauge on my dash for the pressure on the drives so I know that if its 60 or below I'm not overweight. I would think if there was a similar gauge reading the pressure in the trailer then you could avoid going to the cat scale more often than not. Does anybody have such a gauge? I know the technology has to exist for such a system and I can't understand why all trucks don't have these because it would save a lot of time and would totally pay for itself but not having to scale.
  3. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Just get a t valve and add an air gauge. Get a full load, swing by a cat scale and verify your air gauge and legal scale weight. Done for less than $50
  4. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Our trailers are a mix of PSI gauges and calibrated weight boxes. In a large fleet where trailer swaps happen regularly, the gauges are not terribly useful since most have about a 2 PSI +/- variance at 34k (in our fleet of Great Danes... 34k may be 76 PSI, or it may be 80 PSI)
    I guess it depends on precisely where the ride height is set at.
    stwik and ChaoSS Thank this.
  5. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Stexan has it dead on.
    My tractor scales are accurate enough to know that I'm not over on my drives, but unless I scaled an earlier load and compared it to the trailer scales I don't trust the scales to know that I'm not over gross, which is often more important since I pull a spread axle and almost never have problems with axle weights. It does come in handy with weird loads that you can't tell where the center of the weight is.
    However, part of our fleet stays with their trailers and so long as they make sure they are staying calibrated, can know how much they weigh and where that weight is without a scale. Very convenient when a load might take a few hours to set up properly and the nearest scale is 30 minutes away.
  6. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    Had this on my Trailking lowboy,pretty accurate,once you calibrate it.
    KANSAS TRANSIT and Rusty Trawler Thank this.
  7. AModelCat
    159,112
    Like was stated above, T into a trailer airbag after the leveling valve and run to a gauge. If its your trailer, you'll figure out what pressure you need to be at to be legal. I've seen some guys with super b's get creative and run the airlines back up to the truck through a 2nd set of gladhands and mount the gauges in the window of their hedache racks so they can watch the gauges as they get loaded and not have to leave the cab.
    not4hire and Midnightrider909 Thank this.
  8. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Here's a question for you @NorthernMechanic
    would it be possible to make an air gauge in a line that you can connect between your truck and trailer red gladhands? Would it show you the same as T-ing into an airbag on the trailer? If it is possible it might be something for people to carry around if they haul many different trailers to know if they are for sure under or are for sure need to scale it.
  9. AModelCat
    159,112
    If you're talking to read suspension pressure then no. The red line will be charged to ~120psi at all times the brakes are released. The gauge would have to be connected somewhere in the line between the air bags and the trailer leveling valve.
    gokiddogo Thanks this.
  10. cdgoza
    cdgoza Light Load Member
    212
    128
    Jan 24, 2015
    Had one on my dash at Beelman. All company trucks did and most o/o's as well. Our trailers had a quick connect and the tractors had a air line equivalent to fifth wheel slide line to plumb it all. Very handy since we usually pulled the same trailers as well as had to load off our gauges as well.
