can someone help me name the part at the top of the transition where I have it circled. the 2 tubes going under the transmission are leaking air. at least one of them and I want to go buy them to replace them. your help would be appreciated..
Transmission Help Kenworth T660 mx13
Discussion in 'Kenworth Forum' started by ALBANIA1912, May 13, 2019.
Couldn't you just remove the hoses and take them to a hydraulic supply place? They can make pretty much any type of hose you need. They'll match them and build them for you while you wait...
RustyBolt Thanks this. -
booley Thanks this.
That is your transmission cooler. It has oil from the transmission as well as coolant from the engine running through it
pushbroom and spsauerland Thank this. -
Could always just buy some hose and reusable field attachable fittings. Looks like -10.
wore out Thanks this. -
Leaking air or oil?
spsauerland and wore out Thank this. -
If its leaking air that is not your problem if leaking oil or coolant than yes your problem is there, there is valve over there is you have a 13 speed right under that this is probably your air leak
QUALITYTRUCK Thanks this.
