Transmission rated at 1650tq and clutch rated at 1850tq…
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 2013Maxx, Oct 22, 2021.
  1. 2013Maxx
    2013Maxx Light Load Member
    95
    21
    Jan 17, 2018
    Transmission rated at 1650tq, and clutch rated at 1850tq. Transmission is an automated Eaton UltraShift. My truck is turned up from 1550tq stock to 1625tq tuned currently. Can I bump it to 1700tq safely?
  3. Lazer
    Lazer Medium Load Member
    637
    828
    Jan 22, 2017
    Why bother? What’s the point?
    If you have the auto, because you don’t like/can’t shift, why worry about the engine hp/torque?
    The transmission is doing your work for you.
    Bean Jr. and Catmando Thank this.
  4. little cat 500
    1,679
    754
    Jan 17, 2010
    Abbottstown PA
    just put it up to 1850 and be done with it
    2013Maxx Thanks this.
  5. 2013Maxx
    95
    21
    Jan 17, 2018
    I can sense the subliminal insults. Just looking for more pulling power without hurting the transmission.
  6. 2013Maxx
    95
    21
    Jan 17, 2018
    Do you think a 1650 rated transmission can handle 1850?
  7. Catmando
    Catmando Heavy Load Member
    809
    2,512
    Mar 15, 2021
    Iowa
    This is like asking if you should burn high octane racing gas in a VW ..
    Pamela1990 and Bean Jr. Thank this.
  8. 2013Maxx
    95
    21
    Jan 17, 2018
    Well should you?
    Pamela1990 Thanks this.
  9. 2013Maxx
    95
    21
    Jan 17, 2018
    I’ll just call Eaton with my part number. I know some transmissions can go 100 or 200 over and some can’t. Just was trying to see if any turnt up guys with experience was in here. Y’all be safe on the road. Peace..
  10. Goodysnap
    Goodysnap Road Train Member
    2,633
    6,014
    Jul 12, 2017
    No manufacturer of a component would ever recommend using a component over its rated capacity. When it blows apart you would then have someone to blame, regardless if you ever intend to do so or not.
    So and so said its was OK?????
    AModelCat Thanks this.
  11. 2013Maxx
    95
    21
    Jan 17, 2018
  • Draft saved Draft deleted
