Is it all possible to convert an 8LL or a 13 speed over to an 18 speed? Or do you have to get a whole different transmission? I thought I had heard you could like a really long time ago. But I'm not sure how true it is or how easy it would be to do if it even is possible. Just trying to learn new things every day.
Transmissions
Discussion in 'Experienced Truckers' Advice' started by HvyHal Gam3ing, May 22, 2021.
I am going take a wild stab here and say no. In a way, you may be able to go from a 13/18 down to an 8. I’m guessing disconnect the splitter, and you are basically there.
Beyond that "upgradeable" trans I think you are looking at a swap.Bean Jr. and slow.rider Thank this. -
You can't claim to be a dirty old trucker until you've blown a tranny or two... or so I've heard.
Its sat night, I'm grilling and mowing. Yes they had the 9 convertibles. But most all standard rt,rto 9 speeds can be made into a 13, 18 for more money. You change the rear box. Which then you must shorten the driveshaft. FRO is not convertible that I know of. Or I never had a reason to check if it was. Still have to verify ratios and torque rating.Bean Jr., Blu_Ogre and slow.rider Thank this. -
I don't know much about the 8LL other than the splitter is where the deep underdrive comes from.
And don't forget that the Super 10 is of that same family. It only has a 3 speed main with a wide ratio splitter. The range shift is controlled by the shifter when it's moved between the 2nd & 3rd gates, and those two gates used the same 2 gears in the main. That feature was why it got stuck with a bad rep. Guys coming down ramps would kick the stick to neutral at too high of speed and the synchronizer would come apart, leaving you stuck in high range.jason6541 and jamespmack Thank this. -
Not my fault, warned the owner it was on its way out for 6 months...Hammer166 Thanks this.
