Truck been sitting for 2 years
Discussion in 'Ask An Owner Operator' started by kenn2632, Jan 19, 2020.
  1. kenn2632
    kenn2632 Light Load Member
    120
    63
    Nov 25, 2010
    baltimore,maryland
    Can you guys tell me the risk of buying a truck that's been sitting for 2 years. It's a 2006 freightliner classic with a cat C15. I have the opportunity to purchase the truck, but would like some feedback before pulling the trigger?
    blairandgretchen Thanks this.
  3. ltzSupra
    ltzSupra Bobtail Member
    37
    27
    Feb 25, 2011
    I had my 2006 Freightliner Columbia sit for 3 years before I started running it. Before I put it on the road, I changed all the wheel seals, brake shoes and drums, every single rubber hose on the motor, all the shock absorbers, and flushed all fluids including, transmission, differentials, radiator and of course the motor. Haven't had any problems so far 4 years later. But I knew the trucks history. Find out from the owner the reason why it was parked up.
    Coffey and rachi Thank this.
  4. Chubby Fly
    Chubby Fly Medium Load Member
    569
    796
    Nov 25, 2019
    well hopefully they started it every month or so to keep things lubricated and cycle the brakes. 2 years isnt that bad though. 5-10 years with no start is bad.
    rachi and Bean Jr. Thank this.
  5. kemosabi49
    10,009
    41,489
    Jan 13, 2013
    SW Arkansas
    I had an 03 Columbia that sat for 2 years when I went to work overseas. Started it once at @ a yr an ran it for a while. When I got ready to run I changed all of the coolant hoses and changed the oil. Didn't mess with the wheel seals but I did keep a close eye on them and did have one of the drive seals start leaking. Ran the truck 2 more years with only regular maintenance.
    blairandgretchen and rachi Thank this.
  6. blairandgretchen
    12,048
    60,659
    Dec 9, 2011
    South west Missouri
    The risk is potentially enormous.
    I’d never buy one without being able to pull an oil sample and dyno for operating inspection.
    TallJoe Thanks this.
  7. The Biggest Dawg
    The Biggest Dawg Light Load Member
    177
    98
    Oct 16, 2019
    [Location Not Found]
    How do you pull an oil sample without making a mess? What if the oil change is fresh?
    TallJoe and blairandgretchen Thank this.
  8. Chubby Fly
    569
    796
    Nov 25, 2019
    Most cats have the quick valve installed in oil pan. You just put a coffee cup under it and fill her up.
    kenn2632 Thanks this.
  9. blairandgretchen
    12,048
    60,659
    Dec 9, 2011
    South west Missouri
    Then you walk away.
    kenn2632 and TallJoe Thank this.
  10. blairandgretchen
    12,048
    60,659
    Dec 9, 2011
    South west Missouri
    Honestly - it’s like buying anything without knowing if it works.
    I’d never do it with a truck unless it was selling for scrap price.
  11. jeastonjr
    jeastonjr Light Load Member
    99
    120
    Nov 4, 2013
    Weymouth,Ma.
    When you start the engine look for blowby. This will tell you a lot.
