Truck driver arrested for DUI, evading following 20-mile pursuit on I-15 in semi with shredded tires
Discussion in 'Trucking Accidents' started by TheLoadOut, Apr 21, 2021.
  1. TheLoadOut
    TheLoadOut Heavy Load Member
    731
    2,566
    Nov 6, 2019
    CEDAR CITY — An Illinois man was arrested over the weekend following a 20-mile pursuit by authorities on Interstate 15 while driving a semi tractor-trailer with two shredded tires. The suspect remains in custody on multiple charges, including felony evading and DUI.
    The vehicle was reportedly swerving “all over the place,” the deputy noted
    According to the probable cause statement filed in support of the arrest, on Sunday night shortly after 10 p.m., a Washington County Sheriff’s deputy received a report of a blue semi truck headed north on I-15 pulling a white trailer with a blown rear tire. The vehicle was reportedly swerving “all over the place,” the deputy noted.
    The person who contacted police told emergency dispatch they had followed the vehicle for several miles, but the driver showed no signs of stopping.
    The sheriff’s deputy spotted a truck matching the description of the semi near mile marker 27 just north of Leeds and noticed there were two blown tires on the rear of the trailer. He reported that the semi continued swerving in and out of the travel lane. When he activated his lights and siren and attempted to initiate a traffic stop, the truck continued north.
    To ensure that the driver was aware there was a patrol vehicle behind him, the deputy pulled alongside the truck and motioned to the driver several times to pull over.
    “I called out that I was in pursuit and continued to attempt to get him to pull over,” the deputy recounted in the report, adding that the driver still didn’t stop.
    The deputy continued pursuing the semi for more than 20 miles before deputies managed to get the truck pulled over, at which point the driver reportedly stepped out of the truck and, instead of complying with the officers’ commands, started walking toward the deputy, swaying and having difficulty maintaining his balance as he did so.
    They noticed the distinct odor of alcohol coming from his breath
    The deputy also noted that the driver repeatedly refused to comply with his commands, including the order to place his hands on his head and get on the ground. The suspect also appeared confused and had bloodshot eyes. As deputies restrained him and placed him in handcuffs, the deputy wrote, they noticed the distinct odor of alcohol coming from his breath.
    Inside of the semi’s cab deputies recovered an open container of alcohol that still contained “a drinkable amount” of alcohol in the can, and when the deputy advised the driver that he would be run through a series of field sobriety tests, the suspect refused to do the tests “because he wasn’t going to pass,” the deputy wrote.
    When asked if he had been drinking, the deputy said the suspect initially told the deputy he had not but later said he had been drinking.
    The deputy determined that the suspect was “not capable of safely operating a motor vehicle.”
    Authorities later discovered was driving on a suspended commercial driver’s license
    The man was later identified as 38-year-old Grzegorz Paul Wroblewski of Elmwood Park, Illinois. Authorities later discovered was driving on a suspended commercial driver’s license. His standard license was also suspended, the deputy wrote.
    Wroblewski was transported to Purgatory Correctional Facility and booked on multiple charges, including third-degree felony evading, as well as driving under the influence of alcohol, driving on a suspended CDL and reckless driving, each a misdemeanor. According to the probable cause statement, Wroblewski also has a pending DUI case in Illinois.
    District Judge Michael G. Westfall signed the order to hold the suspect without bail and Wroblewski remains in custody at this time.
    Trucking Jobs in 30 seconds
  3. mjd4277
    mjd4277 Road Train Member
    8,005
    17,567
    Oct 4, 2015
    Fitchburg,MA
    Illinois Secretary of State must’ve dropped the hammer on him since he had a pending DUI case there so he probably decided “F*** IT!”.
  4. Flat Earth Trucker
    2,051
    4,994
    Nov 19, 2018
  5. lovesthedrive
    lovesthedrive Is here to help
    14,401
    45,406
    Nov 11, 2008
    Sorrento Maine
    Not surprised. This section of the forum is littered with people whom ignore they no longer have a license. Unfortunately jail is the only thing that will stop these drivers
  6. jamespmack
    163,685
    This is exactly why I think public hangings should be reintroduce.
    JoeyJunk Thanks this.
  7. buzzarddriver
    2,297
    4,403
    Feb 1, 2011
    Dallas, TX
    Sounds like the last place you see before they "draw and quarter" you.
    Opus, JoeyJunk, tarmadilo and 4 others Thank this.
  8. calnca
    calnca Medium Load Member
    359
    667
    Apr 2, 2014
    White Volvo???????
  9. TheLoadOut
    731
    2,566
    Nov 6, 2019
    Might be blue in this case.
  10. mjd4277
    8,005
    17,567
    Oct 4, 2015
    Fitchburg,MA
    I would’ve put my money on a red Volvo as a second guess but that’s just me.
  11. M22 rockcrusher
    M22 rockcrusher Bobtail Member
    36
    32
    Nov 21, 2020
    Waadddd yooouuu saaaay abot my tars oscifer
    Bud A. and mjd4277 Thank this.
  • Draft saved Draft deleted
