Truck Driving Rough After Changing Rear End
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Leonard1983, May 16, 2025.
  1. Leonard1983
    Leonard1983 Bobtail Member
    13
    Sep 28, 2023
    2019 Kenworth t680 paccar mx 13. Changed the front rear end and the truck drove smoother than it did with the old rear end. After 3 days the truck started driving rough. I could feel shaking in the steering wheel and under my feet. Also, I could not hear the truck shifting gears from neutral to first and reverse after replacing the rear end. Now, I can hear it shifting. The truck is beating me to death.
  3. JB7
    JB7 Road Train Member
    1,001
    1,767
    Dec 13, 2022
    Laurel, MD
    Sounds like something may have come loose. Check to make sure that the nuts on the yokes are tight. Also check the nuts/bolts on the u-joints. And check the fluid level.
    '88K100 and Oxbow Thank this.
  4. Ridgeline
    22,717
    122,856
    Why change the rear end?
  5. Leonard1983
    13
    Sep 28, 2023
    Because the old one went out. We took out the drain plug on the bottom of the housing and chunks of metal came out.
  6. xsetra
    xsetra Road Train Member
    5,195
    7,145
    Aug 21, 2011
    Did you replace with new, rebuilt or used?
    Automatic or Manual transmission?
    Does the system have proper air pressure?
    Did you inspect old rearend and determine what broke?
  7. Leonard1983
    13
    Sep 28, 2023
    Used
    Automatic
    Yes
    Planetary gears
    Oxbow Thanks this.
  8. Oxbow
    Oxbow Road Train Member
    13,631
    141,267
    Nov 24, 2015
    Planetary? Real heavy spec then?
    My thought would be wondering how clean the housing was, and if some metal made it out to the planetary.
  9. Inderjit
    Inderjit Heavy Load Member
    768
    735
    Sep 17, 2017
    Like a previous poster suggested make nothing is coming apart. Check the thru-shaft output bearing as well.
    Buy a new magnetic drain plug, get a drain pan and swap out the new drain plug with the old one. See if there is any debris on it or in the oil that came out. There will be a small amount of fine metal no mater how good a job the person who replaced the diff of cleaning the housing.
    Oxbow and AModelCat Thank this.
