Truck is shutting off after idling for a couple of minutes?
Discussion in 'Volvo Forum' started by Lcelaya, Aug 18, 2019.
  1. Lcelaya
    Lcelaya Bobtail Member
    20
    Aug 18, 2019
  2. starmac
    starmac Road Train Member
    6,677
    12,435
    Apr 11, 2019
    Fairbanks Ak
    If yoi are talking about when you crank it up, it runs a minute ofr two and dies, it is probably low on water or oil OR one of the sensors has gone bad. If low, top it off, if it is a sensor, unplug it to see, it will run but leave your check engine light on.
  3. Lcelaya
    20
    Aug 18, 2019
    It's a personal truck I just purchased...its a 94 volvo white gmc wia
  4. Lcelaya
    20
    Aug 18, 2019
  5. Lcelaya
    20
    Aug 18, 2019
    Its triggering a dash light but the problem is the light cover is broken so I have no clue what the symbol may be...I've tried searching for images but no luck
  6. starmac
    6,677
    12,435
    Apr 11, 2019
    Fairbanks Ak
    Unplug the sensor and see if it runs.
  7. Lcelaya
    20
    Aug 18, 2019
    Trying it now it seems to be working so far!
  8. Lcelaya
    20
    Aug 18, 2019
    Thx for the help!
    KB3MMX and Josey Wales Thank this.
  9. starmac
    6,677
    12,435
    Apr 11, 2019
    Fairbanks Ak
    Did your warning light on the dash go off, if not I would be trying to find out what it is.
    FlaSwampRat Thanks this.
  10. stayinback
    stayinback Road Train Member
    3,922
    8,185
    Jan 24, 2014
    chicago,il
    You seem way too relaxed here...
    Did you buy it just to play with it for a hobby...Or are you genuinely concerned about the problem because you need to put it to work?
    FlaSwampRat and x1Heavy Thank this.
  • Draft saved Draft deleted
