a few days ago i went to crank up my rig and it would not say crunk without the key in the start position. If i let the key go completely the truck turns off! Someone told me it could be a fuse but i don’t have a diagram to know which one is the ignition fuse. I personally don’t think it’s the fuse. Bad ignition maybe. I have a 2006 Freightliner Columbia. Help please!
Truck only stays running when key in start position.
Discussion in 'Freightliner Forum' started by SeawrightFreight, Apr 24, 2018.
First guess, ignition switch.
Time to get your multi-meter out and check.
Good luck -
Your ignition switch is worn out, remove and replace.
If it was a fuse, your truck wouldn't even start, so since it does start it means your ignition switch internally is worn out.
The switch is 11 years old, it did its job. -
if it was a 58 Ford it would be the ballast resister
Did you find out what’s wrong, my truck doing the same thing, new ignition switch also
