Truck power steering maintenance, change oil & filter?
Discussion in 'Questions From New Drivers' started by Chicago123456, Sep 15, 2021.
  1. Chicago123456
    Chicago123456 Light Load Member
    67
    22
    Nov 27, 2020
    am I ok to change the filter and leave the oil as is ? it is pretty dark. I think it is time to swap oil as well ?
    I plan to use ATF. I like what the guy did here
    connect 1/2" ID on pressure side ...then crank the engine, refill till you see red color pouring out, top it off...and it is done. volvo vnl 2013, 1M miles ..ATF good ?
  3. Espressolane
    14,872
    84,353
    I would not recommend using ATF.
    While similar, it is not the same. Yes, they are both forms of hydraulic fluid, they have very different additives. Best to use the factory recommended products or an equivalent.
  4. uncleal13
    uncleal13 Road Train Member
    3,757
    6,199
    Apr 9, 2009
    Humboldt, Sk
    Freightliner Cascadia says when you change the filter, undo the bolts that hold the reservoir and tip it over to drain it out. Then top up the reservoir with new Mercon III fluid.
    I saw a video where the guy drained out the power steering box, but that’s not the recommended procedure.
  5. Snailexpress
    2,654
    6,034
    Apr 28, 2014
    Rocky
  6. Ridgeline
    20,732
    101,008
    Dexron II or Dexron III atf for a volvo.
    actually Mercon is ok but not the preferred fluid.
  7. Chicago123456
    67
    22
    Nov 27, 2020
    owner's manual on volvo web page calls for Dexron II or Dexron III...so what is the "preferred" fluid according to you ?
  8. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,481
    Nov 11, 2008
    Sorrento Maine
    Uuuh if you dont own the truck. The companies frown on company drivers servicing company trucks
    Cowboyrich Thanks this.
