Truck pulls to right
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by EricS., Oct 28, 2020.
  1. EricS.
    EricS. Bobtail Member
    6
    Oct 23, 2020
    2009 t800 kenworth.
    Steering pulls to the right , tires swapped air psi checked , no other steering issues.
    Thinking the camber is off ???
    King pin ?
    If its camber how to adjust?
    Thank you
    Trucking Jobs in 30 seconds
  3. AModelCat
    80,978
    Camber is "non-adjustable" but some shops will cold bend the axle to tweak the camber.
    I'd look at everything suspension and steering related. Even the rear axle alignment can affect how well the truck handles in a straight line.
  4. truckdriver31
    5,562
    6,127
    Sep 18, 2013
    so when you swapped the steer steers from right to left. did the truck start to pull to the left
  5. bryan21384
    bryan21384 Road Train Member
    5,602
    8,147
    Sep 18, 2009
    The great state of TN
    Start with the basics first.....once you did work on the steers, you should have got an alignment
    truckdriver31 Thanks this.
  6. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,318
    4,558
    Mar 19, 2018
    Nashville
    I had a 2018 Volvo that did the same. They did a complete thrust alignment and it still pulled. The POS shop manager said well that's all we can do. So one evening I got the might manager, a really smart guy, and he started looking. He finally said it's your tires. Took off the Bridgestones and put on Michelins and fixed it completely.
  7. uncleal13
    uncleal13 Road Train Member
    3,153
    4,602
    Apr 9, 2009
    Humboldt, Sk
    If there’s nothing notable on the front end, then it’s the back end.
    If your rear axles aren’t square to the frame ( thrust angle) then the front has to steer to compensate.
  8. EricS.
    6
    Oct 23, 2020
    No
  9. EricS.
    6
    Oct 23, 2020
    Been begging for one guess it's not in the budget.....
  10. EricS.
    6
    Oct 23, 2020
    Yeah I was thinking that the camber was set but was not sure
  • Draft saved Draft deleted
