Fuel lines from tank to Y splitter are new. Also new both tanks vents.
Truck idling fine with low fuel and pulls good. No changes in boost or engine load. I have KR scan gauge so i can monitor ECM
Truck vibrates/shakes when fuel tanks are low on fuel
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Slow302, Oct 5, 2019.
Page 2 of 13
I think problem is with fuel is splashing in tanks when fuel is 1/2 or less. Or something triggers vibration and then fuel splashes in the tank. But vibration is not left and right or forward and back, Its up and down
Trucker61016 Thanks this. -
You may have cracked fuel pick/up tube in the tank that has the fuel pick/up down in the bottom of tank?
Trucker61016 and Rideandrepair Thank this. -
By shutting off engine you've eliminated it, so look closely at driveline.
Make sure all your U-joints line up, sometimes people put them together off a couple splines and go nuts trying to find a problem.
Make sure no suspension parts are binding. Check carrier bearing.Trucker61016 and Cabinover101 Thank this. -
All u joints are new, yokes line up. Nothing binding up
Cabinover101 Thanks this. -
How about carrier bearing?
Is it a long single drive shaft, or a couple short ones? Are the shafts straight?
Its 1 long than 2 short driveshafts plus short one between diffs. I have them ballanced together. And installed how shop told me to line them up so jokes matches
Page 2 of 13
