So would you say a 2017 RAM 3500 DRW with an Aisin and 3.73 gear ratio is up to snuff pulling a 3 car wedge weighing 7,500 lbs and 3 vehs total weight of 15,000 lbs is adequate?
Would you say a 2017 F350 DRW with an Torque Shift 6 and 3.73 gear ratio is up to snuff pulling a 3 car wedge weighing 7,500 lbs and 3 vehs total weight of 15,000 lbs is adequate?
I do realize each perspective vehicle gives their tow capacities, but I would like info from the actual day to day experience and not just towing 100 miles a few times a month.
Thanks in advance.
Trucks Trans and Gears
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by AUTOFR8, Dec 30, 2017.
Based on what’s on the road either or works.
In reality, go buy a single axle- they last longer and will run better. Cheaper to purchase as well.AUTOFR8 Thanks this. -
You may buy a truck an cut off back axle then move rear drive axle to ft. then you will have a stick shift and be able to haul with no p/u truck bounce ride?
Thanks gents for the information. I ended up with a 2017 3500 Ram with 7,400 miles and warranty at a decent price. It has an Aisin and 4.10 gear ratio.
