If I store stuff in an unplugged freezer at "room temperature" in a vehicle what will the temperature fluctuations be in the freezer?
Seems to be silly, but I have excercise resistance bands and don't want to take them with me on vacation and would rather leave them in my semitruck (which will sit under hot Houston sun for a week). I was thinking of storing them in my mini-fridge freezer, but obviously I can't have the freezer on for a week as it'd drain the semitruck battery.
The temperature outside will fluctuate between 75⁰F-95⁰F everyday. That means the temperature inside the truck cab will fluctuate between 95⁰F-115⁰F everyday. But, what will the temperature fluctuations in an unpowered freezer be?
Unpowered Freezer Temperature Fluctuations
Discussion in 'Experienced Truckers' Advice' started by PianoManCJS, Jul 16, 2026.
If you put as many as will fit of bottles of water in the freezer to freeze before shutting it off, and the door is never opened, i would say the inside temp would stay at or below 75-80 for 6 or 7 days. Just a pure guess only.
Dang, I don't have the time for freezing water bottles.
I assume the temp in the freezer will reach the temp of the truck cab within a day if freezer is turned off. It's usually recommended to open a fridge or freezer if it will unpowered for days, otherwise the smell from the "science experiments" that start growing will smell like a skunk's behind.
86scotty Thanks this. -
And since it is insulated it will take a longer time to cool back down.
tscottme Thanks this. -
I supposed that.
Anyway, I saw that I had enough luggage room to take the bands with me.
So, case closed.tscottme Thanks this.
