us xpress or pgt
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by miz860, Dec 8, 2010.
  1. miz860
    miz860 Medium Load Member
    539
    94
    Aug 23, 2010
    Philadelphia, PA
    Hello all I am looking for advice. If you were a student and had pre hires from these 2 companies which one would you choose and why? Any information is greatly appreciated.
  3. jellybean
    jellybean Medium Load Member
    324
    65
    Mar 1, 2010
    Central MD
    Well it depends on what type of work you are looking for they are two very different carriers in that regard. USX is a dry van carrier and PGT is a flatbed/curtainside/conestoga carrier. There are many threads on here about each company overall PGT has gotten all positive reviews from what I have seen and as for USX they have gotten a mix of positive and negative reviews. PGT will require more training for you being a newbie because you will have to learn how to properly secure and tarp. PGT will also be a much more physically demanding job. You will have to lift tarps and chains and binders and strap and secure loads. Tarps full of snow/ice/water are VERY heavy ask any of the flatbedders on here. The info that follows is what I was told by a PGT recruiter I have never worked for them I was offered a job after filling out an application but declined because I decided to stay where I am currently working. PGT runs mostly east coast they do not go west of I35 (Texas) and expect you to stay out 2 weekends a month. They haul a lot of steal (coils, re bar, pipe, plates etc) and a lot of dry wall. Now from what I have seen they have very well kept equipment and they will train you properly before cutting you lose on your own. You live in a good area for them. On the other hand USX as I said before is all dry van. It will be very little physical work except for drop/hooks and maybe the occasional driver assist unload (I do not know their policy on driver unloads they claim to be 98% no touch and 60/70% drop/hook). They are listed as a 48 state carrier whether you will actually run all 48 is a different story. Both companies run into Canada. I would personally choose PGT. Good luck with whichever you decide on!
    OttMan Thanks this.
  4. miz860
    539
    94
    Aug 23, 2010
    Philadelphia, PA
    Thank you. I appreciate you taking the time to read and respond to my post.
  5. crowhrse
    crowhrse Bobtail Member
    44
    5
    Dec 11, 2008
    Marcus Hook,Pa
    Hey Miz,
    They way I see it,anybody can pull a dry van,but if you go an learn flatbedding you will have a more diverse expericance to put on your resume down the road. I was taught old school trucking and was taught that the more different types of trailers you have experiance with will keep you working longer. In my 31 years I've driven tri-axle dumps,dump trailers,dry van,reefers,flatbed,and hauled heavy equipment,and last was tanker. Good luck on whichever company you decide to go with.But personally I'd go with PGT just to get the expericance.
  6. jellybean
    324
    65
    Mar 1, 2010
    Central MD
    You are very welcome miz be sure to let us know where you end up!
  7. miz860
    539
    94
    Aug 23, 2010
    Philadelphia, PA
    This is very good advice I can always go to a van division and just get up and drive but at my age who knows what might happen so you are right the experience will get me places I appreciate you and your advice.
    I will let you know as I go along. Now to see if I can get the website creaters to start a dac report forum for PGT.
  8. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    Crowhrse is 100% correct. Doing van freight is seldom more than opening and closing a pair of doors. The biggest challenge is getting into tight docks and making sure the top of the door locks are hooked. Doing open deck work is much more challenging as YOU the driver are solely responsable for the load securement and to ensure that it is not damaged by your securement.
    Take the deck job if all things are equal as it raises you a notch higher.
  9. miz860
    539
    94
    Aug 23, 2010
    Philadelphia, PA
    To let you guys know I am looking for the best hometime that's why I choose these 2 companies. US Xpress said they can get me a dedicated account that will get me home every weekend and during the week. PGT is mostly every weekend.
  10. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    USXpress is about as bad as covenant. id opt for PGT if i were in your position.
  11. OttMan
    OttMan Medium Load Member
    321
    207
    Nov 2, 2013
    Georgia
    I will be on orientation for PGT on January 6... Now, moving from Dry Van to the Flatbed folks... Here we go PGT folks!! - Then I have to change my Avatar to a Flat-bedder...:mcool::mcool::mcool::mcool:
