volvo 78O CB radio....
Discussion in 'Volvo Forum' started by nikmirbre, Jan 23, 2013.
  1. nikmirbre
    nikmirbre Road Train Member
    5,431
    9,810
    Jul 27, 2011
    High Point NC
    Im trying to install a new coax, How do I access it in the mirror???
  3. standingtall
    standingtall Light Load Member
    64
    23
    Oct 31, 2012
    I seen drivers take the whole thing apart to do so door panel and all, I've talked to cb shops and they just run new on the out side.
  4. nikmirbre
    5,431
    9,810
    Jul 27, 2011
    High Point NC
    Yeah but i cant run it outside. Not sure how to open and close door with the coax.
  5. standingtall
    64
    23
    Oct 31, 2012
    Do it on pssenger side, wrap around the handle inside the door and out the door jam
  6. v6killer
    v6killer Medium Load Member
    448
    122
    Dec 6, 2010
    ChicagoLand
    I believe that plastic molding that sits next to the windshield and the door is called a paler I think, It has to be removed if you want to get to the wires in question from outside the mirror, the rubber molding on the door has to come off and the grab handle to get into the truck has to be removed.
    I'm in the process of doing the exact same thing, I like my truck inside and out with no wires and strings bouncing around it's just me.
  7. standingtall
    64
    23
    Oct 31, 2012
    I thought maybe he was at a truckstop and needed it fast to roll down the road. Sorry. And yes I would make it right too. I like neat.
  8. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    2 black plastic plugs in the back of the cover need to come off then 2 torx screws to take the cover off, bottom of mirrror brace has 2 torx screws, bottom mirror brace to door cover pops off.that will open up every thing from the door to the top of the mirror so you can run your coax
  9. nikmirbre
    5,431
    9,810
    Jul 27, 2011
    High Point NC
    Flood, mine doesnt have those two plastic plugs on the back of mirror. Its just flat back there, no screw holes or nothing!!!
  10. flood
    4,161
    4,031
    Dec 25, 2010
    what year is it....
  11. nikmirbre
    5,431
    9,810
    Jul 27, 2011
    High Point NC
    my truck is a 2OO6 78O
