Volvo d13 2012 shake, vibration, bad mpg
Discussion in 'Volvo Forum' started by Pendula, Dec 14, 2017.
  1. Pendula
    Pendula Bobtail Member
    Hi guys. I have Volvo d13 2012 with I-shift, and 293000 miles on engine. I have a problem, the truck is shake between 1300-1500 rpm and dont have power to change gear. Also when I idle the truck is shaking. The mpg is bad between 5-6. Does anyone know what can be the problem.
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    I'd probably look at injectors.
    Dave_in_AZ and Socal Xpress Thank this.
  4. boneebone
    boneebone Road Train Member
    2,295
    2,366
    Mar 13, 2009
    It may be bad injector or /and injector cups.
    Dave_in_AZ Thanks this.
  5. QUALITYTRUCK
    1,804
    1,765
    Jun 14, 2009
    romulus,mi
    This very well may be the simplest, popular, yet most expensive diagnosis in the history of truck repair. If you have witnessed the symptoms in person enough times, you don't even have to open the hood to diagnose. Good thing because o/o will need every penny saved to complete the repair.................until next year when it happens again and so on and so on.....................
  6. Dave_in_AZ
    384,232
    2012 with only 293K?
    I loved my Volvo like that. But I sifted through many to find one that had already had the injector cups done.
  7. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    I second that.
  8. Amram
    Amram Medium Load Member
    448
    234
    Feb 4, 2017
    I should have bought a cummins.
  9. d281833
    881
    919
    May 15, 2012
    I had an ISX, it was a boat anchor. Instead of injectors it was cam problems. They all have their own issues.
  10. Amram
    448
    234
    Feb 4, 2017
    Im having low power issues now. Hoping its not injectors.
  11. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    the Volvo d13 is known for bad injector cups
