Volvo D13 gas pedal not responding for a second and like air coming out of somewhere, when accelerating and in high rpms. As well when i let my foot of the pedal and shifting into 10th gear, it does this couple of times a day, any help would be greatly appreciated, Took it to few mechanics couldn’t figure it out what is it, no codes as well or check engine light. The sound coming out from the Driver side, no visible leaks as well.
Thanks
Volvo d13, when accelerate i hear sound like air coming out of somewhere, and the gas pedal for just
Discussion in 'Ask An Owner Operator' started by Grashakot, Feb 15, 2019.
Possible boost leak? But would think you'd hear it most of the time if it were.
Check air intake manifold to compressor hose for leaks
I’ll tell the mechanic to have a look, thanks, altough i have replaced the intake presure sensor and the venturi pipe, when i took the truck from the mechanic after a day started doing this, and it bothers me sooooo mich
I recently had my EGR cooler sensor replaced because the check engine light was on, but had been noticing similar antics to what you are experiencing. The Volvo shop replaced my turbo speed sensor, which was not sending out a code and the problem was resolved.
