Volvo Ishift Transmission air leak
Discussion in 'Volvo Forum' started by Oacosta, Dec 27, 2021.
  1. Oacosta
    Oacosta Bobtail Member
    I’m havig an issue with my volvo Ishift transmission. Its leaking air from on top of the transmission and the mechanic dont know what is causing it. If i supply air to the truck using another truck the leak stops
  3. nasriza
    nasriza Road Train Member
    2,201
    1,792
    Feb 1, 2013
    Chicago, IL
    Probably cylinder housing is leaking thru or your tecu is bad just had this prob 2 weeks ago
  4. Oacosta
    How did you end up solving it?
  5. nasriza
    2,201
    1,792
    Feb 1, 2013
    Chicago, IL
    Drop trans out. Removed cylinder housing and tecu and supplied air pressure to run tests on bench found out tecu was leaking replaced it programmed and all good.
  6. nasriza
    2,201
    1,792
    Feb 1, 2013
    Chicago, IL
    Where is truck located
  7. Oacosta
    New Jersey
  8. nasriza
    2,201
    1,792
    Feb 1, 2013
    Chicago, IL
    I don’t know if your mechanic can do it u need special wiring to be able to remove housing from trans. Either u have to find someone that can work on this or take off trans and send it to reman place like Weller maybe they can fix it u can bring it by me I can fix it don’t know anybody out there that can do this. If it is tecu they r on back order right now from Volvo so r the housings. I usually try to keep stock and should have it but again I’m in chicago no where close to Jersey.
  • Draft saved Draft deleted
