hi I have a 07 Vo Levi vn 630 d12 and I’m having an issue the switch on the dashboard for the sleeper fan and the one on the sleepers are blinking and when I have the sleepers light on it will shut it off on its own and will start beeping any ideas ? Thanks
2007 Volvo vn630 electrical problem with sleeper fan.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by combo7, Oct 22, 2018.
Do the basics....... check the grounds and make sure everything is nice and tight with no corrosion.
Does your truck have the battery cut off switch? That thing builds up resistance and makes things go wonky.combo7 Thanks this. -
the power supply to the sleeper is acting up check all the terminals behind the sleeper contol and make sure they are all making proper contact usually this takes care of it very problematic on volvos
Socal Xpress and combo7 Thank this. -
Thanks for the reply’s it turn out to be a bad battery and a DEAD alternator, all fix now thank God !!!
JohnC123 and Socal Xpress Thank this. -
combo7 Thanks this.
