VOLVO VNL 2011 Cummins isx won’t crank
Discussion in 'Volvo Forum' started by RoadRanger^^, Aug 31, 2023.
  1. RoadRanger^^
    RoadRanger^^ Light Load Member
    196
    73
    Apr 17, 2018
    Columbus, OH
    Hello guys,
    I was on vacay for two months and today when i went to start up my truck, of course batteries were dead. My buddy came to jump start it with big jumper starter and first time when i tried to start it did crank but start to smoke around the batteries somewhere, after that we tried one more time cranked but had no power to start and smoked again, after that truck won’t crank i just hear click. Do you guys have idea what could be the issue ? blown fuse ? wires ? something got burned ?
    Any help is welcome!
  3. AModelCat
    141,445
    Sounds like a failed battery. They'll smoke if a cell is shorted.
    Siinman Thanks this.
  4. RoadRanger^^
    196
    73
    Apr 17, 2018
    Columbus, OH
    My friend came also with his truck, we ran jumping cables from his truck to my truck and it shows 12.5 but like i said still no crank :( do you think one battery will make the truck no to crank at all.
  5. Snailexpress
    2,628
    5,997
    Apr 28, 2014
    Rocky
    How battery connection looks? Do you have quick disconnect switch above battery pack?
  6. RoadRanger^^
    196
    73
    Apr 17, 2018
    Columbus, OH
    I do have quick shut off switch. I replaced it 2 years ago because i had the same issues truck sometimes had power sometimes not. Batteries looks okay. Mechanic was cleaning them last time they have like some black stuff around i guess for protection against corrosion
  7. Snailexpress
    2,628
    5,997
    Apr 28, 2014
    Rocky
    Check fuse from battery to the cab and fused link to the frame. Fuse holder is right on the battery, fused link is black wire from battery negative to the frame, not the big one. The fuse in this wire is calibrated copper covered by shrink tube close to frame bolt. If it's soft in this place the fuse is burned.
  8. flood
    flood Road Train Member
    3,947
    3,622
    Dec 25, 2010
    What transmission....
  9. RoadRanger^^
    196
    73
    Apr 17, 2018
    Columbus, OH
    Eaton Fuller 13 Speed Manual
  10. flood
    3,947
    3,622
    Dec 25, 2010
    Ok.. I was going to say with auto's the transmission can cause the truck to not crank
  11. RoadRanger^^
    196
    73
    Apr 17, 2018
    Columbus, OH
    I replaced all 4 batteries still nothing. I just hear click around starter area
  • Draft saved Draft deleted
