I have 2006 Volvo VNL 780, am getting sudden power loss and loss of speedometer, engine brake and loss of cruise control. I heard speed sensor could cause symptoms except, I am not able to throttle at all and engine stays in idle range with no pedal response what so ever.
Any help?
Volvo VNL 780 loss power and speedometer
Discussion in 'Volvo Forum' started by JayFlow116, May 22, 2017.
Page 1 of 4
Your Accelerator Pedal and/or your Pedal Position Sensor could be bad or going bad.
The symptoms you are describing are common when those parts are failing.
It could also be your Speed Sensor failed, in that case your Speedometer will not work and your truck will go into Limp Mode, but your truck should still accelerate.Metalicious and Bakerman Thank this. -
Acceleration pedal sensor, speed sensor, engine break switch connected to the VECU. From VECU to ECM all signals transmits in digital mode by J1939. Terminating resistors sometime can create this problem.
How to check J1939 terminating resistors - Forums / Diesel and Chassis Electrical and Electronic Systems / Troubleshooting the J1939 Data Link with a Calculator - Truck & Diesel Mechanic Forum - ASE Medium/Heavy Duty Truck ForumJohny41 Thanks this. -
What's the code that's popping up when this is happening first of all please check u don't have a shorted Qualcomm cable for one maybe an old one. Second make sure the plug in the speed sensor it's making proper contact. I've never replaced one accelerator pedal in 10 years working of Volvo they almost never go bad
Vasilebanc Thanks this.
When that happened, the check engine light would come on until I pressed on the pedal again and the ECM received a signal again and it would start working normally again until the next time.
It eventually got so bad I finally replaced it and it has been fine since.
My friend's 200O Volvo Accelerator Pedal is starting to go out on him too, same symptoms that I had and his code says Accel Position Sensor.
It ECM doesn't set a hard code at first, but it will eventually. -
Page 1 of 4
