W900L leans to right
Discussion in 'Kenworth Forum' started by cumminsISB, Jul 10, 2011.
  1. cumminsISB
    cumminsISB Light Load Member
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    Looking at front of truck it leans or seems lower on passenger side than driver side and that is on level ground. Buddy says it may be shocks. Is that a possibility? Don't know how long the ones on it have been on there. also where would be a good place to buy shocks?
  3. rjones56
    rjones56 Heavy Load Member
    823
    486
    Jul 15, 2008
    staunton va
    Springs or related hardware or both.Could have had one spring replaced.Shocks won`t do that.
  4. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    There are blocks between the steer axle and the springs that regulate the height and sometimes they can add or remove shim sections to level the truck out.
    If the truck wasn't leaning when it was new there could be another issue at play here but it is probably just the spring on one side "settling" a bit and it can be corrected at any decent front end shop.
  5. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Get the fat girl out of your truck....:biggrin_2554:
    captw900, misterG and 7122894003481 Thank this.
  6. blackw900
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    She's stuck...Can't move her.:biggrin_2556:
  7. Les2
    5,150
    2,288
    Jul 25, 2008
    Get an other to level the truck out then....:biggrin_2559:
  8. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    not sure if it was like that when it was new I just bought it 3 weeks ago....it bothers me to look at it though. Will check that block later this week.
  9. Freebird135
    Freebird135 Road Train Member
    1,527
    906
    May 7, 2009
    In the air conditioning
    i also tend to lean to the right
  10. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    yep went and looked at it and the right side is missing a shim that is present on the left side...would a 3/8 shim cause that noticable difference?
  11. Les2
    5,150
    2,288
    Jul 25, 2008
    Yes 3/8 is a lot.
