Kenworth to unveil the W990 on 9-28-18
Discussion in 'Kenworth Forum' started by larry2903, Sep 20, 2018.
Page 1 of 6
Not as pretty as W900 but nicer than a t680 Kencadia. I can see small fleets, tanker, and skateboard outfits picking em up.
Cheap crap for the masses.
W900 wannabe. For those that can't decide if they want a hood or an aero truck. Maybe they're going to let the truck figure out for itself what it identifies as. No surprise in today's screwed up world.
If it ain't broke...
How is the w990 an upgrade from the w900?MartinFromBC and jsnell Thank this. -
If you haven’t seen how the 2.1 cab is constructed, you should have your local Kenworth or Peterbilt body shop contact you when they’re going to strip the interior out of one and put in a new cab due to an accident. The Kenworth dealership I use let me look at a day cab that had laid over, wasn’t a high speed accident, but cab did need to be replaced. The cab maintained its structure enough that the interior was able to be reused, including the rear window and complete dash. The 2.1 cab is spot welded, air craft style riveted and some type of sealer used on every internal seam inside the cab adding to the insulation of the cab and sleeper from temperature and noise.spsauerland Thanks this.
Page 1 of 6
