Water droplets forming on the inner rim of where you pour engine oil.
Discussion in 'Experienced Truckers' Advice' started by Gurjap, May 9, 2021.
  1. Gurjap
    Gurjap Bobtail Member
    37
    7
    Mar 18, 2020
    Hello friends,
    I have a Kenworth t800 which has a Cummins isx engine.
    I opened the cap and noticed there were droplets of water around the rim from where I would pour engine oil into my engine. Is there something to be worried about? What seems thr be the problem? Please let me know thanks.
    Trucking Jobs in 30 seconds
  3. Moosetek13
    Moosetek13 Road Train Member
    11,608
    11,691
    Nov 1, 2010
    Burnsville, MN
    Might just be some condensation.
    How does the oil look on the dipstick?
    Crude Truckin' Thanks this.
  4. AModelCat
    100,465
    Just condensation. Do you idle a lot?
  5. skallagrime
    skallagrime Heavy Load Member
    997
    1,842
    Apr 10, 2012
    Indiana
    Immediate oil sample, you could have caught a failure before its catastrophic, or you may have just added some oil where it was humid or raining.
    Either way, an oil sample is cheap peace of mind
  6. baha
    baha Road Train Member
    3,757
    2,319
    Jul 25, 2013
    ga
    Or another driver in the next fuel island may have showered your eng. as you were getting oil to add when the fill cap was off? If you have any thing hi/er up than fill cap that you can pull off and ck for water or white oil on it may give you a better idea of how much water could be in the oil, but oil sample is best done quick !
  7. Gurjap
    37
    7
    Mar 18, 2020
    It looks completely fine. Black in colour
  8. Gurjap
    37
    7
    Mar 18, 2020
    Yes it does idle here and there but nothing which is considered “a lot”
  9. wis bang
    wis bang Road Train Member
    1,981
    1,697
    Jan 12, 2011
    Levittown, PA
    All crankcases build some condensation in the vapors.
    The oil cap is a good place for it to condense from vapor to water droplets.
    Sometimes it is an emulsion of oil and water vapor that appears as a light yellow slime in the nooks and crevices of the cap/fill area.
    The new car that does not 'use' oil between changes is being topped up by condensation as every engine has some oil flash off on every piston stroke.
  10. Moosetek13
    11,608
    11,691
    Nov 1, 2010
    Burnsville, MN
    Water in oil will turn it a bit brownish and cloudy, and there may be bubbles.
    Black is good.
    Gurjap Thanks this.
  11. Moosetek13
    11,608
    11,691
    Nov 1, 2010
    Burnsville, MN
    Any new engine will use a bit more oil as it breaks in, but once the rings fully seat there should be very little loss until the rings start to degrade.
  • Draft saved Draft deleted
