water leaking through roof of cab. 379 ( 2003 ).
Discussion in 'Peterbilt Forum' started by Lone Ranger 13, May 30, 2013.
  1. Lone Ranger 13
    Lone Ranger 13 Road Train Member
    1,542
    1,297
    Sep 27, 2012
    Asheville, NC
    Water leaks through roof. Doesn't matter if parked or moving. Much water gets in. I have been on the roof and can't see anywhere it could get in. But a lot does get in. Tried pulling down back edge of headliner, but still can't see underside of roof to see where water is getting in. Anybody know where it would be most likely to leak.
  3. drozzer69
    drozzer69 Road Train Member
    1,206
    1,142
    Oct 20, 2012
    Spring, TX
    Do you have air horns on the roof? Either there or maybe where the antenna comes out in the middle. Also check around the sleeper seal if you have a sleeper unit. Only three places other than the clearance lights that I can think of.
    Lone Ranger 13 Thanks this.
  4. Real Deal
    Real Deal Medium Load Member
    468
    230
    May 29, 2012
    Saint George UT
    I fought a roof leak on my 379 for a long time once. Ended up being a hairline crack in one of the marker light lens.
  5. hmtruk
    hmtruk Light Load Member
    123
    49
    Jun 7, 2009
    big lake ,mn
    horns , they rust through ,or the seals under the base. lights
  6. Cab Lizzard
    Cab Lizzard Light Load Member
    118
    45
    May 16, 2011
    MIA
    I got wet carpet passenger side only. From front post it spreads out to about the middle of the seat. Its driving me nuts.
    New rubber seals on doors, cab and window. Fresh caulked all around windshield.
    Anyone had this ?
    Visor ?
  7. Flightline
    Flightline Road Train Member
    2,343
    1,162
    Oct 1, 2011
    Almost There
    Cab lizard, I had similiar problem, ended being AC drain stopped up. My ac was then draining in the passenger floor board.
    I couldn't beleive how much water could come out of AC.
    Now I have roof leak. Thinking one of my 4 air horns.
    Cab Lizzard Thanks this.
  8. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    Air horns, cab lights, windshields, you name it. Every Pete I've driven has had a leak somewhere, even when they were new. Pull the headliner out and spray water on it til you find it.
    Kw Owners Club Thanks this.
  9. Flightline
    2,343
    1,162
    Oct 1, 2011
    Almost There
    My Peter leaks too. Always thought it was drinking to much. LOL
    cheeseburger and Sublime Thank this.
  10. casepoor
    casepoor Bobtail Member
    Red Rock, OK
    I had the same thing on my 2000 379 and could never figure it out. I was finally mad and pulled out all the american class interior and started looking. The leak was very inconsistant and would leak on the fuse panel and behind the seat. I figured out that the rivits in the cab roof cap were all loose and some stuck out past the surface, especially in the front and the back corners. The water travels around the loose rivits and into cab behind windshield then runs down moulding and down corners. I put black silicone (black truck) to stop the leaking.
  11. Luwi67
    Luwi67 Heavy Load Member
    714
    449
    Oct 24, 2012
    Long island
    Find the leak yet?
