ways to keep fuel pedal engaged?
Discussion in 'Experienced Truckers' Advice' started by TruckerRawb, Apr 12, 2022.
Page 1 of 5
Shim the pedal to desired rpm.
Can use a piece of wood. Cut it to the desired length that will keep the pedal where you want it.
There's a tool also, if you can find where to buy it. Fit between the pedal and bottom of dash, then you adjust it to where you want the pedal to be.Flat Earth Trucker and Big Road Skateboard Thank this. -
check amazon, NAPA, AutoZone, O'Reilly's, PepBoys, etc.Flat Earth Trucker, Bean Jr. and Chinatown Thank this. -
Did you try pressing the cruise control then set button.
GYPSY65, kylefitzy and mustang190 Thank this. -
buddyd157 Thanks this.
CorsairFanboy, Moosetek13 and Chinatown Thank this.
Screw driver.
How about just turn on the Opti Idle and let it so it's thing. It might be a simple solution till you change it. If it has the 8 batteries electric a/c and works it won't start very much.
Bias_racing and Cat sdp Thank this.
Page 1 of 5
