weight distrobution
Discussion in 'Experienced Truckers' Advice' started by gharr8, Apr 22, 2010.
  1. gharr8
    gharr8 Bobtail Member
    45
    Oct 15, 2009
    dfw, texas
    Best advice to distribute weight. more weight on the tandems than on the drives??? currently, weight is even but could move some weight back to tandems?? my tires, my truck. would like to save wear on drives. now at 72k
    thankx
  3. jtrnr1951
    jtrnr1951 Road Train Member
    even is best, or a tad heavier on drives
  4. last 1
    last 1 Medium Load Member
    439
    184
    Nov 29, 2009
    IMHO the ride is so much better with the weight as close as possible to each other. I use to always load trailer heavy when it wasn't my trailer and tires but the ride would be terrible.
  5. jedi_tev
    jedi_tev Light Load Member
    201
    20
    Oct 11, 2008
    Las Vegas, NV
    For me it depends on my load, my fuel, the routing, the distance of the run. I like to keep the load and truck as close to balanced as possible. Sometimes I'll shift weight to the tandems for I can run with more fuel. It's nice to have a day or two w/ out stopping for fuel.
  6. Trouble65
    Trouble65 Medium Load Member
    621
    147
    Jan 11, 2009
    Ontario Canada
    Having an extra 2000 pounds will not save wear on your drives. However more weight on the drives would be safer in my mind, especially in wet road conditions.
  7. Allow Me.
    10,759
    12,532
    May 28, 2009
    Rancho Mirage, Ca.
    Heavier on the front end if given a choice. (drives VS trailer tandems)
  8. dab11999
    dab11999 Light Load Member
    59
    36
    Feb 5, 2010
    It's always better to go heavier on the drives. You get better fuel mileage because you're pulling the load instead of dragging it. Heavier on the back causes your drives to bounce up and down and that forces your fuel pump to try and compensate even though it doesn't really need to.
    Also gives you better traction on wet or slick roads.
