What is the most weight on the axles of doubles/triples without getting an overweight violation?
i don't see it posted anywhere and done pretty thorough search. any experienced LTL driver's might know this question's answer.
weight restrictions/limits/violation capacity of doubes/triples?
Discussion in 'LTL and Local Delivery Trucking Forum' started by kidz bop, Dec 30, 2017.
20K per single axle.
so 2 axles on truck, plus 4 axles with 2 trailers. that's 6 axles. 80k weight on the 2 trailers, then more weight on the truck? wouldn't that add up to being over 92k weight limit for everything? that doesn't sound right, where was my math wrong.
The same thing for gross weights.
Every state is different and that is why you see doubles and triples in some states and not in others. Some states allow weights up to 105500# or more with the right permits.Last edited: Dec 30, 2017
carl320 Thanks this.
And just 'cause you're running triples, doesn't mean you're going to be running max weight. There's lots of high-bulk, low-weight freight out there, and it's what LTL generally specializes in.Mike2633, upnorthwpg and MACK E-6 Thank this. -
Mike2633 Thanks this.
Depends on the state laws.
When I ran linehaul, our rule of thumb was 57/59k lbs of freight for Rocky Mountain Doubles/Triples respectively. Then when you add your equipment weight, you would scale right around 106k which is legal for my state of Montana.
Another rule of thumb we use is 1k lbs per foot of trailer length. So if you are pulling a 48 ft long box, if you are over 48k, you probably won't scale. This is for twin screw.
If you are running a single axle, your long box will not legal if you go past the 20k (of freight range). 16k is safe... Anything above that up to 19k is strictly based on a skilled forklift operator that knows how to load out.
Oddly enough, you can pull a pup with up to 23k of freight and still be legal with a single axle.MACK E-6 Thanks this. -
im sorry. I thought this was a thread about dispatchers being willing to "sign off" on single axle weights that are 1,200 lbs over....
