well I bridged a car!!!!
Discussion in 'Road Stories' started by earthbrown, Aug 27, 2007.
  1. earthbrown
    earthbrown Medium Load Member
    362
    38
    May 27, 2006
    I took a job as a car hauler 2 months ago, and it is truely challenging.
    Friday morning, I was hauling up to town, dropped off 4 cars, and had to pick up 3 on my was through and drop them on the way to drop my 4 other cars....
    Well I drive a cab over car hauler, and had my head rack car raised about 2 feet over down, so the car was probably 15 feet at the trunk wich was higher than the front.
    I loaded under the top, which is normal, and lowered the decks back down, forgeting the headrack, I even hight checked the otther decks, but some how missed the headrack...
    I got on the expressway, and .0000001 before i went under my first bridge, I knew i @$#R@%ed up, .0000001 later I hear a bang and know I really an screwed. I pull over hoping that the convertable on the headrack had the roof blow up by chance and it wasnt my fault, BUT, I had left the deck up, and took out the top, and trunk, luckley it was a convertible as a roofed car would have been totaled.
    Called the boss, did not beat around the bush, and I had to go unload the car access the damage and get the car to the collision shop to fix so the dealer could get the car.
    Bad week for us, 3 of the 5 trucks are messed up, had another bridged car this week from another driver....
    This job is fun, but time consuming, I find myself pushing due to other drivers being sick or off and the work still there, I am not being pushed, but I am pushing myself, as I am a pusher, I am not pushing myself to make $$$< I am pushing myself cause I know there is work to be done, and I need to get it done in my head....
    after my 15months otr, I was upto 240lbs, after 2 months of car hauling I am down to 215 with 20 lbs left to lose, it is a great job, and it never ceases to be challenging, and PAYS AWESOME, I have brought home $1000 or more EVERY week.
    K
    Trucking Jobs in 30 seconds
  3. longbedGTs
    longbedGTs Heavy Load Member
    975
    715
    Texas
    Two brothers that were yard jockeys with me went to hauling cars. One had a mishap with an Expedition. He didnt crank the car down enough and an overhead beam ended up crunching the roof. He was responsible and paid for it...about $500 I believe. He makes enough money to be able to recover from that in 1/2 week.
  4. Bullwinkle
    Bullwinkle Medium Load Member
    594
    26
    Jun 11, 2006
    Texas
    I can just imagine the sick feeling I would have had in my stomach when I heard that noise.
  5. Pete_379X
    Pete_379X Super Chrome
    1,006
    123
    Jul 4, 2007
    I've always wanted to get into car hauling, but the right people aren't around here. I've heard there is tons of money in it.
  6. Bullwinkle
    594
    26
    Jun 11, 2006
    Texas
    We have a company that delivers to dealerships locally here, and they actively recruited me when I was working as an assistant service manager at one of the dealerships.
    Union job, they said 60K+ to start. At the time, I was making better at the dealership. Even after that, I thought about it, but I am not real fond of heights and don't really care too much about the idea of climbing around on that rig and backing cars down wet ramps.
    I have watched these guys slide off the side of these trailers and total cars, that basically convinced me to avoid it.
  7. RBPC
    RBPC Short & Sassy
    554
    119
    Jun 20, 2007
    Where I Want To Be
    This is the reason, I believe, my s/o doesn't get home as much as we think he should. That sounds just like him. Do they call that taking your work home with you, or since you're a driver, it's taking your home to work with you. :confused4:?
    Good thing: You're a hard worker. Dependable. Flexible. :dontknow:
    Bad thing: You're exhausted. You/You're family misses out.
  8. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,906
    12,177
    Sep 17, 2006
    WY
    Unless that dent was very slight and the shop was able to do a paintless dent removal you probably need to add another 0 to that figure. That is way too cheap from what I know.
  9. longbedGTs
    975
    715
    Texas
    I guess I should have clarified. Yes, it was a minor dent, but none the less, it was a mishap with a brand new car. BTW, he was less than 1 month on the job at the time.
  10. weasellyone2
    weasellyone2 Bobtail Member
    Ridgeway, Ontario
    The hardest part of car hauling are the first few months. Once you find the tie down holes and invest in a good height stick, let the good times roll and the fat pay checks follow.:biggrin_25525:
  11. Brickman
    12,906
    12,177
    Sep 17, 2006
    WY
    Once I had the upper deck put a crease in the roof of a cherry F150. The dealer was NOT very happy. It had a a lift kit on it, and I had pulled a lot of the lift out of it tying down. I didn't think and let the chains loose before lifting the upper deck.
    I did 9 months of car hauling when I first started driving. Now almost 5 yrs later I've come full circle and am starting a new job monday hauling cars again.
  • Draft saved Draft deleted
